We value your privacy.
>First of really like new look. I have a 30' by 40' shop with good size dust collector1300cfm. It has 3- 4" ports can i get by running 4 inch metal duct pipe all the way around on seperate vanes or try to go to six inch or stay plastic 4. Sorry lots of questions. Thanks curt
>Whoa! The 1300 CFM is probably the typical overstated manufacturer's rating measured with no pipe and a clean filter. You likely have a 1.5 hp - 2 hp DC with a 12" diam. impeller which realistically moves only about 800 CFM or less at the machine when connected in a fixed system even with 6" ducting. It is woefully under-sized for a 30' X 40' shop! Depending on your machines and duct runs, you need a DC with 3 - 5 hp motor and blower with 14" to 16" diam. impeller. 4" ducting is undersized for most shops and woefully so for the size of you shop. The CFM through a 4" pipe is less than half of that possible through a 6" pipe. You are killing flow from the start with a 4" tripple wye on the blower- remove it. I know this is not what you want to hear. I suggest you go to Bill Pentz's site and do some calculations for your shop and machines.
>Curt About if you should run PVC, in my opinion most definently YES. I put a, Oneida 5HP cyclone in about 6-7 years ago and ran PVC, I`ve always ran PVC, and would never run anything else, unless something beter came along, and it works great. It is so easy to work with and better yet it`s so easy to redo when you want to move things around, and at some time you will move things. Another thing is you are not going to get cut as easy with PVC. GOD LUCK with whatever you do Larry
>I agree with both of the above. Go to Bill Pentz's site and read up.
I used light weight (Schedule 35?) Sewer and Drain (S&D) PVC and have no complaints. I would say you need at least 6" for the main runs and 4" for the branches. The S&D stuff has a limited array of fittings. I used two 45's to make a "swept" elbow and a Wye and an 45 in place of a tee. Even then the pipe and fittings were so cheap it was OK. Much cheaper than the heavier (Schedule 40?) plumbing stuff.
Pentz's site has a section on making your own fittings. If I had known it was there I probably would have made some of my own, but then it just seemed fascinating to ME.
It would be foolish and strangle your system to run all four inch pipe. You can have two gates open at the same time if you branch fours into six. It does come up occasionally even in a one man shop.
This is a popular subject here and comes up often. Once the Archive are re-established you can search them.
>Curt, I've just completed running 6" PVC in my garage. Somebody here referred me to AG Lock & Hardware at http://www.acehardwareoutlet.com/%28wapzzpitguxk0i21jchkoi45%29/Default.aspx for inexpensive fittings and I saved 50% over buying them local. Link posting isn't working yet but you can paste that URL into your browser.
My space is about 21' x 24', I bought a used Oneida with a 1.5 Leeson motor. I have 6 drops but only have 1 open at a time. 2 of the drops are 6" with a 4" 'Y' and 1 of the drops goes from 6" into three 4" 'Ys'. If I open one of the drops and hold my hand over it, it literally sucks my fingers up into it. Not a scientific test but at least I know it won't have any trouble with wood chips.
I haven't sealed any of the pipe joints but once I'm confident I won't be moving them I'll run tape around all the joints. I bought a Long Ranger 220v remote (Amazon $56) and it works very well. I'm waiting to get a couple 6" blast gates from *bay and I'll be done. Good luck & enjoy!
>I used 4 " PVC to feed a 2hp General. I have a 25' run down one side that collects three machines and a floor sweep. I don't usually need two gates open, but its happended by mistake and still works fine. I have no complaints and judging by the repeated need to empty the collection bag overal my system works great.
Minimize the curves and flex pipe as you would with any layout and I think you'll be very happy with PVC.
Agree with comment about PVC being easy to work with and redo if necessary.
>i am having a hard time locating 6 inch pvc thin walled a 6 inch y they want 22 dollars for and this is the thin stuff what my other alternatives or am i looking at the wrong stuff
