Grizzly oscillating sander spindles
Paul Blackwell
>I have a Grizzly oscillating spindle sander with 9" spindles. Does anyone know any tricks to getting a new sanding tube onto the spindles? I've removed the tightening nut and washer off the top, and other than the largest tube (4"), I haven't been able to push the tubes onto the spindles. I've tried lubricating with water, and reluctantly, with oil to no avail. Any suggestions?
Re: Grizzly oscillating sander spindles
Robin Corell in Atascadero CA
>remove the rubber drum from the metal spindle and that should let you get the sleeve started. If the nut was tightened sometimes letting the drum sit over night after you remove it from the metal spindle will let it relax a bit. Once the sleeve is started position it so the sleve is a few inches above a table and the rubber drum is sticking out above it and let it drop/bring it down onto the table, repeat as many times as necessary. no lube is nesessary.
Robin
