Check the alignments again...(sorry!)
Grant in Iowa
>Check alignments again... if your blade is a sharp dedicated rip blade (suggest a Freud or better), then check in order:
1. Miter slot to blade parallelism. Dial indicator setup mounted to your miter guage is best, but a board clamped to your miter guage and some feeler guages can also do the trick. Dial indicators can be had for as little as $15 at places like Harbor Freight.
2. Miter slot to fence parallelism... again... dial indicator is best, but other methods can work if you are careful. While you are doing this, move your fence left and lock it, right and lock it, etc a few times to be sure that when it is locked in place it remains aligned the same. Lots of low end fences that lock in the front and rear of the saw table suffer in this regard. If the fence can't lock and provide repeatable parallelism, then it is to blame.
3. Fence straightness: Use your best straight edge to see how straight your fence is. You can also detach the fence and lay it on its side on the table saws top to check it.
Tell us how these checks work out, and tell us what kind of blade you are using (brand, and number of teeth) and we'll offer more input. Also tell us the brand and model of the saw, since many of us will have direct experience with adjusting it.
It is also possible that the wood you are cutting is not evenly dried or has internal stresses for some reason. If you rip a board and then lay the two back together, they should fit together tightly... if not then the board, not the saw is to blame.
Regards,
Grant in Iowa
