Resawn veneer backer
Jeff
>I am going to be resawing some Sassafras to make veneer for some drawer fronts and panels for a platform bed. Unfortunately, I won't have enough Sassafras to make the backer veneer, so I'm looking at other species.
In searching around the internet for wood movement calculators, I've found that, of the readily available species, Alder and Ponderosa Pine have the closest shrinkage rates when drying, but I wonder if those properties translate to already dried wood. Can I presume that the drying-shrinkage numbers are similar to the already-dried numbers?
If the above numbers are good, I also wonder how close I need to be on the backer material. For instance, Ponderosa's shrinkage percentages are within 3% of Sassafras, and Alder is within 10%. Poplar, which is markedly cheaper (and easier to find than Ponderosa), is at 15%. Is this too large a difference?
Thanks for your input, and a Happy New Year to all,
Jeff
