pvc-wood bond
pvc-wood bond
pvc-wood bond
Gerald Gibbs
>The project is a large version of a marble roll game with short pieces of pvc glued to plywood. Used dabs of epoxy. The joints are failing. I know there are many variables, such as surface preparation, area of bond etc, but I need to know if I am on the right track. Jerry Gibbs
Re: pvc-wood bond
Re: pvc-wood bond
Gerald Gibbs
>Just thought of using 3M 5200. Jerry Gibbs
Re: pvc-wood bond
Jesper, Denmark
Re: pvc-wood bond
Jesper, Denmark
>You are probably doomed to failure. PVC does not glue well. PVC-PVC glues are really solvents, which dissolves the PVC so it adheres to itself - not likely to work with wood.
At least the PVC needs to be scuffed well to make some tooth, but I still doubt if it will stick long term.
Re: pvc-wood bond
Re: pvc-wood bond
Scott Crumpton
>About the only way to get a bond with PVC is to use a solvent based cement. PVC cement is basically acetone with dissolved PVC, but my not be thick enough to fill the gaps in a wood/PVC joint. What I would try is to first coat the wood with cement and allow it to set up for an hour or so. Then apply some to the PVC and press the parts together.
Re: pvc-wood bond
Re: pvc-wood bond
>As Jesper stated, PVC is very difficult to glue. As he also stated, most PVC glues for PVC to PVC bonds are solvent glues. They actually dissolve the PVC and sort of "melt" it together.
That being said - I have had limited success "gluing" PVC to rough surfaces with the PVC pipe glue. I put enough of the PVC pipe glue down to get the surface of the PVC sort of "sticky" and I've pressed it to a rough surface. It worked for my application. I don't know if it will work for yours.
In the industry in which I used to work, we had flame treaters and corona discharge treaters (spark) to treat the surfaces of various plastics (PVC, PET, etc.) to make the glues stick better. Treating the surface of your PVC in a similar fashion may also work.
Re: pvc-wood bond
?design modification
John E in SC
>Could you modify your design somewhat? My thought was that you could drill and countersink the PVC enough to screw it to the wood, but if that would mess up your marbles rolling, you might could do that to a larger piece of pipe, then use PVC solvent to glue your correct size piece to the larger piece. Or you might even be able to use PVC fittings (screwed in place) to hold the pipe. My other thought would be that silicone MIGHT hold for a while, but I doubt it would be good long-term.
Re: pvc-wood bond
try an elastomeric adhesive
Bill Tindall
>I have not experimented with gluing PVC but I think a solvent based elastomeric adhesive will work. I would experiment with E6000 available at any hobby shop or maybe elastomer caulk such as used for gutters or auto windshields.
Re: pvc-wood bond
Re: pvc-wood bond
Jim Pugh
>Check out the Weldbond website and see if it will work. Good all around adhesive.
Re: pvc-wood bond
Google "this to that" and see what they say
Re: pvc-wood bond
Might be worth a phone call *LINK*
Walt Smith
>From Roo Products website:
Can RooClear� be used to bond materials other than melamine?
Yes, RooClear� will bond to many materials including: vinyl, rubber, metal, stone, ceramic, many plastics, corion, solid surface material, HPL, fabric, even painted and UV coated surfaces. Please contact Roo for technical help.
Roo Glue
