Workbench Drawers and Cabinets
Ed Beck
>I have about 2 feet of vertical space and 6 feet of horizontal space for drawers and cabinets. Any suggestions on drawer width and height? I want to have a variety of depths, shallow on top for smaller tools, and deeper on the bottom.
Whatever I don't use for drawers I'll use for a cabinet.
Re: Workbench Drawers and Cabinets
Ed Beck
>I'mm planning on using drawer hardware like the Rockler 755.
doug f, san clemente, ca
>Ed - When I built my workbench I added a bank of drawers underneath. Depths are from 2 1/2" to 6". For me they're perfect for storing planes, marking tools, small clamps... the kind of stuff I use at the bench.
They serve a duel purpose. I made them all with 100#, full extension slides and they serve as an additional brace for big pieces that I put in the vise.
If I had some more room I would have put in a couple shelves to store routers; but that's another bench.
Have fun with your project.
Doug
Ed Beck
>Oooooooooo, now that's smart. I never would have thought of using 100# slides so I could brace the wood. Thanks, I'm defintely going to use that one.
>I have two cabinets of drawers. The top drawers are about two inches deep and they are filled with hand tools, one for screw driver type stuff and one for wrenches. It might be better to have more drawers but shallower. Just deep enough for one layer of tools. Other wise you are laying them on top of each other and not only do they get lost, they might damage each other.
I have a number of deep drawers for routers and nail guns. The smaller Nial guns will stand up in the drawers, that's a good fit. For the router drawers what would be useful would be a second shallow drawer for all the little stuff like attachments and bits, or a tray inside the deep drawer. So, My thought is, sort out the stuff and measure it. One of mine is just the right depth for drills and jig saws to lay on their side. I have a separate shallow drawer for drill bits and other drill "stuff".
Think it through. How would you organize? All big stuff in one drawer regardless of its purpose, like routers and nail guns and skilsaw all in one or would you put routers with attachments in one and the skilsaw in another?
Another thought. I have another cabinet with full extension rails under my lathe. They are hundred pound runners. The sort that is a track in a track in a track. The problem is that they came with some heavy grease in them and it collects saw dust. They get "gritty" and sort of rumble when they open. I blow them out occasionally and wipe them, but it a nuisance. My older cabinets have some aluminum stock epoxied into rabbets in the sides as runners. Not full extension, but they don't collect crud and have worked smoothly for over 25 years. So, If you get the kind that are greased, I would say remove the grease. Also, Generally heavier runners run smoother than lighter runners. There is a benefit to 100lb runners over 50 lb runners even if they are lightly loaded.
Larry in NW Ohio
>Ed I usually buy my slides from CSHardware, they have quite a few slides and I think a little cheaper. They have a link here at WC. Larry
Larry in NW Ohio
>Barry and Ed If you want a thin drawer for like 1 layer of wrenches, how do you think making a removeable shelf inside a drawer or a half shelf that would slide forward or back to access the bottom of the drawer. I have one and like it. Larry
Phil in Connecticut
>Here is what I did. Blum drwer slides. Sized bottom drawers to fit power tool plastic cases.
Paul Kramer
Other than the Vise -- How do you do Workholding?
Paul Kramer
Everything's a Compromise
Phil in Connecticut
>Like so many things, a bench quite often represents a compromise. For me, as I consider this the utility bench, its primary purpose was to provide organized storage for most of the usual tools/hardware, and provide a basic work surface for routine tasks. I decided to add the front vise since I knew it would be some time before I was able to build a "proper" joinery bench (time and space constraints getting in the way again). However, with the vise and the overhang of the top, you can do a fair amount of work holding and clamping. I'd like to have a "proper" joinery bench some day, but I felt that this bench was needed first. After all, before you can plane against a bench stop or saw dovetails in the tail vise, you need a place to sit your coffee cup and peruse the latest tool catalogs.
Fred Davis
>Ed,
workbench ideas are endless.
I thought about a bench that would serve several purposes for years and shop shot #876 is what I came up with.
A picture or two rather then typing may make your project a little easier.
FredD
Ed Beck
>This is a good idea, it allows you to have two levels with half the hardware. I assume that the top is a tray with sides.
What do you think of foam cutouts for small parts? I think it would be essential if I wanted to have all my router bits in one drawer.
