Re: quick release band saw tensioner
ebd
>Are you nuts? It doesn't hurt the bandsaw, but it definitely hurts the performance and life of the blade. If all you are doing is crude cuts, I'll agree with you. If you are making precision cuts or resawing for veneer or turning thins, for example, I'd say you are dead wrong. Not only won't you get acceptable cuts, but when doing that kind of work you tend to buy premium blades. Leaving tension at full would be like using a fine talesaw blade (for example a Forest) to cut plywood. I ain't gonna' do that.
That said, I've heard that the tensioner doesn't allow you to ignore proper tensioning each time it's used. That's the reason I haven't bought one. If I've got to make the fine adjustment every time then what's the point? Once you get used to the flutter method it's quick and easy. If I was going to invest in anything it would be a crank of some kind for the tensioning knob. That would really speed things up.
