Veritas - Innovation in Tools
Building a tool chest.
Virgil Johnson
>A few months ago I decide to build a cherry toolmakers tool chest. I had a wide cherry board on hand so I cut it up and have got this far to date. The end of the board is on the left. I have an old oak Union chest that I'm using as 'inspiration". I'm going to build this as one solid box and saw the lid off. I'm using different construction methods than the manufacturers of these styles boxes use so that I can use solid wood throughout. Through dovetail corners, frame and panel back, etc.
Re: Building a tool chest.
Slotting machine?
Virgil Johnson
>I have this old machine that I took from the last place I worked when I got laid off. It appears to be a metal working machine of some sort:-) It is useful for cutting slots such as the ones on the side of the chest even thought the the spindle speed is a bit slow. It has a cool counter of some sorts that tracks the XY movement of the table down to three decimal places.
Slotting machine? Virgil, You're joking, Right?
Forrest Addy
>That's a metal working turret mill. I'm sure you recognise it for what it is.
It can be used for wood but as you say the spindle speeds are low. The machine looks fairly new and in good shape.
The number thingy that tracks X and Y movement is called a digital read-out chance are it ha lots of handy features ueful to woodworking.
If you have room for it, a turret mill is a very handy thing to have aroud a woodworking shop. Mot only for wood either becaaue it make duck soup out of precision meatal shaping. Ever get tired fo those crappy hinges and hardware they sell everywhere? Make your own from solid brass. And ue the mill to mortice them into your project.
Who me?
Virgil Johnson
>Turret mill...Well I'll be :-)
Can you help me figure out how to use the "sign" plate that came with it?
The mill a 602 Excello made in the 70's from what I can tell. For fear of a scolding from the gods I don't dare say I rebuilt it but I did tear it down 100% to clean,paint (slathered on porch grey variety), replace bearings in the head, drive belt, made new vari drive bushings, repaired the lube system,. It has a Sony Magnascale readout. Good readout for a dusty environment.
Re: Slotting machine?
Larry in NW Ohio
>Virgil That machine you have looks exactly like the one we had at the place I use to work at. They called it a metal working milling maching made by "EDCO". But I think it was a woodworking maching, it wouldn`t even be very good for that. If you could get it for next to nothing, it would be OK for a home shop. The only difference that I can see is the motor on the one we had sat on the top in the back. One day just after we got it someone was milling some wood on it and the screw that runs it back and forth broke, and that told us how good the thing was. Larry
I'd kill for one of those. I think you need
>to throw it my way. It's obviously useless to you. :)
Um, Virgil...
>...nice gloat, buddy. What a sweet machine to have around.
Gloat?
Virgil Johnson
>I'd be gloating if I told you what I paid for it.... 25.00 (twenty five dollars)
Re: Who me?
Larry in NW Ohio
>Virgil If that was made in the 70`s it may have been made in the US, if so my apologies. But it does look just like the one we had, they must have stolen the design. If is that old you got a very good machine. Did you try to look up the manufacturer on the net? Looks like you did a great job at rebuilding it.Again my apologies. Just like me to get my mouth run full out before my brain gets in gear. Larry
Deal of a lifetime
>Good on you. It takes some really good luck and patience to get the best deals. You've done well.
We're expecting new levels of accomplishment, I hope you realize. :)
Cheers,
Re: Deal of a lifetime
Virgil Johnson
>"We're expecting new levels of accomplishment, I hope you realize. :)"
That thing has been sitting there for close to 7 years now waiting for me to get better. It may be a lost cause.
Nah, just a matter of time :-)
Re: Um, Virgil...
Doug Ridley
>Virgil, it'll have to be some machine to make you much better than what I saw at the first get together(bowl fling).
