Question on 3M disposable masks?
>I wear a 3M 8210 disposable mask in the shop. The trouble is the cheapo yellow rubber straps break. I have tried stretching them and not stretching them. Either way, somewhere during the day, one of the straps just breaks while I am wearing it. Doesn't seem to be due to any stress other than my fat head. Does this happen to everyone or am I doing something wrong? I tried tying them back together, but of course that shortens them and they break again. I stapled some, but that just punches a hole in them and starts a new tear. Some of them break in a matter of minutes. Anybody got a fix?
Re: Question on 3M disposable masks?
Chuck Kettler
>Get a 3M 52P71 at Sears for $30 and you will get much better performance and not have the problem with fit. We have to annual test both of these respirators and if the fit for the disposables is not very careful then they fail relative to the better mask.
del schisler
>i use those I buy them in a box I belive maybe 24 ? short memory I havent had one break with me They get dirty first Maybe old stock ? I buy mine at HD Not that make's a differnce I get the one's that has the vent in frount Helps with glass fogging up my 2 cents del
When I use 3M 8210s or similar disposables...
David Barnett - SW FL Gulf Coast
>I immediately remove the two yellow bands and replace them with a single comfortable wide strap with a fastener that looks like a garter belt clasp but with a half-inch long rectangle instead of the round button. Never too tight, washable, apparently last forever. I believe these came from a forensic medical supplies catalog (I got mine from an M.E.). I've seen people make their own with tiny bulldog clamps, Ace bandage clips, hot glue and elastic, and two pieces of slightly stretchy and very sticky bandage tape mated from the middle to the last inch of each end pinched to the mask sides.
Another thing... these masks are less likely to be compromised or worn too long with a reusable strap. These masks should be thrown out after only moderate use. Although I almost always use a respirator with replaceable filters, I do prefer disposables when working with lower mesh silicas and other ceramic raw materials. I want that stuff gone.
One more tip: I learned to seal my masks to my face with a medical grade silica glue. You can either use it in 'sticky mode' or lay a bead around the mask rim, letting it set so it's reusable for two or three wearings. I prefer Swiss-made Provox silicone glue but other brands are okay and hopefully cheaper. This is an adhesive for securing prostheses, I'm told, but I know of an illusionist and others involved in stagecraft who use it, as well. And don't think about trying even thoroughly-dried hardware store acidic silicone caulk. That ring of rash around your mouth would be painful enough without having to explain how you got it.
I Know Its Hard Top Mask Your Disappointment, Barr
A snappy response, Colonel!
I've had this problem on the real cheapos
>but not on the two-strap 3Ms like the ones you use. And I've got a large head (7-3/4 or thereabouts - I can rarely find hats that fit).
One of the packages of two-strap masks I bought instructed me to put them on like this:
1. Put mask on face, with straps dangling in front of mask.
2. Take lower strap and bring it up over the head, down to where the skull meets the neck.
3. Repeat with upper strap, but putting it just behind the crown of the head.
If you're not doing it that way, you might try it, and see if that improves strap life.
Incidentally, when I use disposables, I've started using the type with the exhaust valve on the front, for two reasons: the water vapor from my breath exhausts more efficiently, resulting in less fogging of the safety goggles, and it's easier to do a seal test on the mask (hold hand over end of exhaust valve, breathe in; if mask tightens up against your face, it's sealing). They're marginally pricier, but I find it worthwhile.
"cheap" fix
Bill Tindall, E.TN
>Cheap as in if you are exceptionally cheap. I staple elastic from the fabric store on them.
Now, if you had just told me yesterday...
>I was in JoAnn's getting findings for ear rings. My memory is so poor I have to make a list. If I go to a store to get three items, all I can remember when I get there is I need 3 things. No idea which three, lucky if I can remember one of them.
Re: Now, if you had just told me yesterday...
Howard Norman
>> My memory is so poor I have to make a list. If I go to a store to get three items, all I can remember when I get there is I need 3 things. No idea which three, lucky if I can remember one of them.<
Welcome to the club!! I don't think that it is a very small club however.
howard
Right, as in
>there's two problems everyone gets as s/he gets older. One is the memory starts to go, and the other is.......
dang, I forget!
+1 for that
Alexandre Grigoriev
Larry in NW Ohio
>Barry Be glad that you can remember that, I usually forget the list, or I forget to look at the list. Larry
Dale Stansbery
>I discovered the Stanley N95's with an exhalation valve to be far more comfortable than the 3M's, and I have no problem with the life of the bands. I couldn't stand to wear the 3M's long enough for the bands to break, They were far too tight (short, inelastic?)to begin with.
Shoot, even when I write it down, I forget
>at least one thing. The love of my life thinks I'm getting senile; just trying to save money...
used washable dust be gone for years
bob davis5098
