ADVERTISE HERE - FREE TRIAL
Woodworkers solution to a natrual problem
Frank on Chestnut Hill
>As I have mentioned before My wife and I own a RV. This year I found a wierd problem. A mouse took up residence in a kitchen drawer complete with seeds and dried up works.... who knew they are into air drying.Set a couple of traps and got a couple but then realized this could take forever.
I made a couple of boxes about the size of half a shoe box with the bottom open. I cut a couple of access holes and placed a good old snap trap inside and weighted the whole thing down with a brick. Got two the first few days. At least they can't do any damage outside on the blacktop.
Don't tell the mouse bloggers. FFG
Re: Woodworkers solution to a natrual problem
Prevention
>While you'll need to air out the RV come summer, I got a great tip a few years ago from someone in our local hardware store: mice hate the smell of mothballs. Buy a couple of boxes and scatter them around when you put the RV to bed for the winter, and you may not have to trap any mice.
mice also hate
Bruce, a MN Galoot
>those dryer fabric softener sheets.
Re: Prevention
Bob Entwisle in NJ
>Moth flakes tend to disolve over the course of the winter so less to collect clean up in the spring. Moth Balls and Flakes are on the must have list for closing up the summer place in Maine.
GalenV in Iowa
>Still need to check out the undercarriage no matter how much trapping and moth balls. Got to be a hole there that should not be. Fresh water drain line out, gray water , black water line, hot water heater drain, gas line, battery line and generator all may have places they may have opened up around. Sheet metal glued or heavy foil repair tape is good to repair around passages.
I've seen people leave gray or black water caps off thinking it will prevent any freezing from small amount in tank. They blew out traps to save antifreeze and makes a nice path for all kinds of critters.
Not just a storage thing either depending on where you camp you can pick up critters anytime. Unless maybe your an asphalt parking city camper.:>) Class C seem to have more possible "holes" than Class A or even a good TT. At least from what I have owned of each.
Good Hunting
jared
>Mothballs work. I put a box of them in the cab of my combine when I am through harvesting. The one year that I didnt do it, mice got in and chewed everything up. Trying to plug all of the access holes is a good idea but is kind of a losing battle. A mouse can get in through a very small hole. Jared
>In pipe access holes in a house, my son uses coarse steel wool or one of those copper scrubber wool things, tucked in around the hole but not compacted, then shot full of spray foam. The foam holds it in place, and the mice apparently don't like to bite the metal wool.
Caution
John Veerkamp, Western Mo
>When using moth balls or flakes, be aware that the active ingredient is naptha. It is toxic and some people are very sensitive to it. Be sure to air the camper out well when returning the camper to use.
John
Re: Caution
Larry in NW Ohio
>Also with moth balls, I think you need to keep pets away from them, and without saying, little children. Larry
Lewis Dodd-aka-- RIPSAWED
>what's the deal here, no one mentioned MEOWWWWWWW!
lEWIS
Thanks to All.
2 more lst night...The hawk must have slacked off
Cats eat until they're full
>Mice may well reproduce faster than that.
