Re: Question on Performax Sand paper
Dave Paine
>I have only ripped one strip I can remember, and this was due to an unevn board so started fine, but later the board was too thick, resulting in heat and overload.
I would not be confident in any tape behind the strip to hold up to normal tension. Good luck. Sucess will depend a lot on the tape used. Maybe the carpet tape which requires heat to set the glue. Should be strong enough. Gets lots of pressure in normal carpet use.
I recently switched to the Klingspor blue Zirconia paper. Major difference. I used to get build up on the rust coloured strips, also from Klingspor.
Finally getting full use out of the strip. Several weeks and easily cleaned up with abrasive rubber cleaner. Expect this to be the first strip to be replaced due to dulling before clogging up.
I have not thought much about which end. I think I start at the motor end since it is a pain, but thinking about the other replies, starting at the end under tension, the end opposite to the motor makes sense.
