Hammer drill criteria
Tom Dunlap
>I have to hang some shelving from block walls so a drill/driver or hammer drill is needed. that's good news since I could use a new battery too.
DW got me addicted years ago so I'm not going to change batteries. I have 18v DW tools so this will be the same. I've been happy with DW too.
This is my first impact/hammer purchase so I have no clue how to spec one out. What numbers or features should I look for?
Thanks!
Tom
Re: Hammer drill criteria
Lewis Dodd
>Hate to bust your bubble, but a good masonry bit and a regular drill should do the trick, even it is glazed. I have a Milwalkee and have used in on concrete mostly, because of the stones in the mix
Lewis
Dan Donaldson
>A hammer drill is one place I would go with a corded tool. The hammer takes a lot of power and is expensive (in cordless) and heavy for normal use. I would buy a cordless drill and a corded hammer one.
>Keep in mind that a hammer drill and an impact driver are two very different tools. A hammer drill drives the bit in a circle and "hammers" it as if it were struck with a hammer. A rotary and linear motion. An impact driver uses rotary impact to drive a screw. they are not interchangeable.
I would try a good masonry bit in a regular drill. If you can find one that costs four or five times what they sell for in the borgs it will work better and last longer. The $1.98 ones don't cut well and don't last long.
I also agree that this is probably a good application for a corded tool. Look at the SDS tools. (Bosch and several other make them. Just bought a Bosch unit and like it. It will hammer or rotate or both.
Howard Norman
>Several years ago I purchased a DeWalt corded hammer drill that was SDS. It was a factory reconditioned one, I think I got it from the place in Denver as I recall. It has done everything that I have asked it to do. Most of my work with it have been on the walls of my basement which are block filled with concrete. I would agree that this is a place where a corded tool is desirable.
I don't recall the name of the place in Denver that sells factor reconditioned tools but I have been very happy with several tools that I have purchased from them over the last ten years or so.
>I agree with others that, for block, a good masonry bit in a regular drill should do the job - block's not very hard.
If you're thinking to have something for drilling into concrete, rock, etc., I suggest that you look for a rotary hammer, not a hammer drill. Difference:
A hammer drill rotates with an added hammer force that vibrates against the concrete/whatever.
A rotary hammer allows the bit to slide a little bit as it rotates, so, when the hammer force is applied, it strikes against the concrete/whatever.
Folks have referred to tools that use SDS bits - these are rotary hammers.
Having picked up a Bosch rotary hammer a year or so ago after years of wishing, I wouldn't go back, and wouldn't buy a hammer drill unless I had a lot - like daily or weekly lot - of small-diameter holes to drill in relatively light concrete.
I have no experience with the cordless rotary hammers, but agree with others that this is a bruising-level job, and a cord delivers the amps you need.
Dang...
Tom Dunlap
>...I might have been talked out of buying a new tool.
I have a 3/8" Milwaukee that has served me well for many years. when I need a cord this is my go-to drill.
Off to look at quality bits.
Took King is the outfit in Denver. I've bought several tools and my 110v Hobart wirefeed from them.
Tom
Re: Dang...
Howard Norman
>Yes, Tool King is the place that I was thinking of in Denver. Just could not remember their name.
howard
Clint Searl
Agree - 1/2" corded
Clint Searl
Now, now
Dan Donaldson
>Let's not get hasty. It still might be a good idea to buy a cordless driver to get the torque to drive the anchors that you are going to put in the holes ;-)
Yes yes...a new drill!!!
Tom Dunlap
>Today I was working in the shop and needed to use my DW 18v drill. The knurling on the chuck has worn a bit smooth. Sometimes I have to get out two pairs of pliers to open the chuck. For the past few uses the slide switch for reverse has been hanging up. After dismantling the drill I got the switch to work. When I put the shell back together the slider won't jockey the switch into reverses.
All this adds up to a new drill.
Tom
Definitely, If anyone Asks, I said it is OK.
Re: Yes yes...a new drill!!!
Larry in NW Ohio
>Yes Tom that`s the same thing I do when I want a new tool, I work on the one I have. Works all the time. {:-))))Larry
Hank Knight
>I agree with Bill. I have a basement shop with poured concrete walls. Several years ago I bought a Bosch "Bulldog" rotary hammer. It has been one of the best tool purchases I've made in a long time. I've used it a lot more than I thought I would. It cuts through hard concrete and cinder block with equal ease. The Bosch sales rep recomended an SDS rotary hammer for all the reasons Bill pointed out and I bought on his recommendation. Great purchase. They make a bunch of sizes. I bought the smallest - 7/8" I think. It has easily handled all my needs in the shop and around the house.
Hank
I'm with Bill
>Once you use a SDS you'll wished you got one earlier.
Possbily overkill for small holes, but works equally well for small holes as it does for larger ones, making a hammer drill obsolete.
I rented a SDS tool to bore a 1" diameter hole 12" in a concrete foundation and it did the job smoother and faster than a hammer drill with a 3/16" bit going 2" deep...... I'm not kidding. Next time I needed one, I just bought one.
Happy Woodworking!
yabut
Bruce, a MN Galoot
>what if I never go larger than 1/2"?
I tried drilling a bunch of tapcon holes with a regular bit, and I wore out three bits getting 6 screws in a 70 year old poured concrete wall. I know a hammer drill would've done the trick, and now I learn that I need a rotary hammer?
Bruce, perplexed in MN by a great many things, not the least of which is my email.
Re: yabut
>I have to confess that I've never used a hammer drill.
But, after watching the bit in a rotary hammer just sink into old concrete with very little effort on my part, I'm a convert.
