OT : BP Meds . . .
OT : BP Meds . . .
OT : BP Meds . . .
steve mackay
>Sorry about OT but its saturday, can't see going to the ER for a, probably, stupid question. Blood preasure meds take effect right out of the gate ? I figured it took two or three days to notice any effect. Everything is okee-dokee but it does appear to have lowered on my nifty new BP meter.
Re: OT : BP Meds . . .
Robert R. Clough - Thorncraft
>I seem to remember that they do take immediate effect - or almost immediate effect. I notice if I miss a dose. Suggest you look this up at Mayo Clinic http://www.mayoclinic.com/
BOB HAINES
>sometimes takes several days to reach a "steady state" serum level.
good luck
Bob Haines
[I'm not an MD but I did stay at a Holiday Inn Express]
Warm fuzzy . . .
steve mackay
>Thank you. Learning a lot about this whole thing but reassurance from laymen makes one feel . . . yadda, yadda. By the way . . . anyone sitting on the fence ( he-he )about a colonoscopy . . . it ain't all THAT bad. Go get 'er done !
Stuart Hough
>Having been on several different types until the Dr. and I found a set that works best for me, in my experience, when you initially go on meds, you'll notice a pretty immediate effect, depending on the type of med. After having been on the prescription for a while, you won't notice a big swing if you miss a dose, but if you miss a day or two, you'll feel the difference , both being off, and then getting back on the meds. There are so many types of medications that work in different ways that it may take several different meds, or combinations (as was my case) to find an effective treatment. Good luck with it.
I hope that warm/fuzzy wasn't about the 'scope??!?
Stuart Hough
Re: Warm fuzzy . . .
Randy Johnson
>The procedure isn't all that bad but the prep is hell.
Didn't notice. Ahhhhh, Demerol !
steve mackay
Joseph Mulherin, Sr
>To help with the preparations of a colonoscopy drink lots of water or liquid diet two days before taking the Go-Lite, or whatever the name is for your meds. Do not eat a heavy meal so there will not be as much poop to discharge. And remember to drink lots of water. I had one done in April and in June there showed up that my 'creatinine' level was four times what it should have been.
Larry in NW Ohio
>I had one done about 2 months ago, and even the prep for me wasn`t bad at all. From when I started drinking the water/med mixture till the end of the clean out, excuss the pun, was only about 8 hours IIRC. Also when the meds started to take effect was about 5 hours and when I was done was another 3 hours. Of course everyone is different. My test was very good and do not need another for 10 years. I wouldn`t hesitate to do another. Larry
Re: Didn't notice. Ahhhhh, Demerol !
Stuart Hough
>I'll remember to ask for that when I get mine done early next year...oh wait! Will this be one of those "medically questionable and possibly unnecessary" types of test? (insert potically-charged personal note of choice here)
Larry in NW Ohio
>Well Stuart I don`t know how else they can see up there without it. Larry
Depends a lot on your particular medication...
John E in SC
>Some BP meds have a pretty quick effect (10-15 minutes for some), but others take up to a couple weeks of regular doses to have FULL effect on your BP. If you have questions, don't hesitate to call your doctor. No one else will be able to answer your questions as well.
(Dr.) John
Re: OT : BP Meds . . . *LINK*
John McGaw
>It is probably not a good idea to generalize since there are so many types of BP medications and not all of them work in the same way. I take Cozaar which took a couple of days to show appreciable results. Other medications will operate literally in minutes (a high dose of the vitamin niacin will convince you of that). The information sheet that came with your prescription should give you an idea about how long the drug should take to begin working. If it does not seem to be working you should consult with your physician -- not every drug is effective in all patients (thus the reason there are so many types).
http://www.nhlbi.nih.gov/hbp/treat/bpd_type.htm#diuretics
