Another Question on rechargeable batteries....
>I have Makita 12 volt rechargeable tools. Drills and an impact driver. Love the tools, hate the batteries.
Three years ago I had four batteries rebuilt at one of the companies that comes up here when the question comes up. Paid for their premium upgrade service. They seemed fine when they were returned, but after three years of casual use some of them have crapped out again. At least one of them won't hold a charge over night and one of them does not last long. (I really do need to do some sort of 'controlled' study, but my shop work is so random that it's difficult to tell exactly what is going on.) Part of the problem is that if I pick up the crappy batteries to take to a job it may not work for more than a minute or two.
I am disappointed. Should I be?
Re: Another Question on rechargeable batteries....
del schisler
>flash them Read the post futher down To see how to do it I have done many and they last quite a while
>Del, I thought about this, but I don't know where I would get a 24 volt source. I have a car and a truck and I could pull the batteries out of them but then I would have to completely reprogram the radio presets and other crap.
I have a trickle charger for car batteries, but that only put out 12 or 14 volts.
Wonder if I could string together my 12 volt Makita batteries and let them juice the others?
Al Stokka - Cambridge, Iowa
>Barry,
Your doorbell is most likely 12 volts.
Al
Larry in NW Ohio
>Your getting into different terretory here. The door bell would not put out enough AMPERAGE that would go with the drill batteries. The car batteries put out something like 300to 400 amps maybe more. Drill batteries are like milliamps same with door bells. Maybe someone else will chime in here and be able to explain it better. Larry
Jim Engel
>Have had a 14 volt battery pack for my
Porter Cable drill with the same problem.
Been through the replace the batteries,
seem to be dead too soon.
Went right out in the shop, flipped on
my power supply, turned it up to about
24 bolts, applied it as directed.
Worked like a charm !
Seems too good to be true, see how long
it lasts.
Larry in NW Ohio
>Jim What kind of power supply did you use? Larry
My poor memory.....
>Had friend and neighbor who was an electronics instruments technician. Light years ahead of me on things electronic. It has slowly come back to my feeble brain that he used to take my batteries and "blow the shorts out of them". I did not know how he did it and it sounded very painful, so I never asked. I lost a lot when he passed away.
Gary Evans--Tallassee TN
>Hi Barry,
I had the same question in my mind after reading the posted article. While I don't know exactly what is happening to the batteries in this procedure, I would guess it is the current flow that breaks up the whiskers that are at the root of the problem, rather than the voltage which is applied. If that is the case, your 12V Makita batteries probably won't do the job. As someone else stated, car batteries are capable of producing hundreds of amps.
I'm going to give it a shot on my 18V Ryobi batteries using the batteries from our Wrangler and Explorer. The time it will take to reset clock and radio presets seems a whole lot cheaper than what the manufacturers are asking for new batteries.
I'll post up when I get done.
Gary
Re: My poor memory.....
Fred Davis
>I am sorry you lost a valuable friend Barry, it's a shame we can't get our memory recharged as easy as he fixed your Batteries.
For you guys who dispense Medical advice on this forum there's a subject for you , Memory loss.
FredD
Power supply
Jim Engel
>I used a home made supply that is variable
and current limiting which goes up to about
25 volts.
I am not sure, but I think something like
a welder is way, way over kill.
If you don't have something on hand, you could
perhaps open up the battery pack and work on half of
the cells at once.
Or if you have a couple of 12 volt batteries I
expect they would work fine in series.
del schisler
>sure the voltage is what you are after Not the amprage Add it up to we will say 24 volt for the 12 up to 18 volt battery's and 12 for the 7.5 battery would work I know a lot of work reprogram radio And sometimes it will mess up the computer in the car also take note !! It may have to be reprogramed by the shop ?? this is what i been told not from experence good luck
del schisler
>glad you done it They should last a long time again Nothing to loose But more hrs to gain When it get low hrs Do it again
del schisler
>That is AC voltage Not DC Don't use that Wont work
Door bell transformer IS AC not DC wont work
del schisler
>wont work Ac not DC We are not after amprage here JUST voltage for flashing
del schisler
>make sure that before you unhook the battery Ask the the place that you got your car that it is safe to unhook battery See if it will effect the computer in car ??? Most places hook up a small 12 volt supply accros the battery post's before they unhook the big battery This way it will not loose any memory Radio ect. You can do this your self no big deal
Re: Power supply
del schisler
>I belive the battery's may be sealed up to where you would have to remove some of the fish paper inside Just more work ?? would work tho
