Cordless drill
Cordless drill
Cordless drill
JohnD
>I need a new drill, my old 14.4 dewalts are failing. I got an input that the Hitachi 18v Li-I is the best drill on the market. Any experience good or bad? thanks
Re: Cordless drill
Rebuild the batteries. *LINK*
>I used them when they had another name.
Of course if you want a new, more powerful drill driver - that is a good one.
MTO
Re: Cordless drill
Re: Rebuild the batteries.
Larry in NW Ohio
>Go to e-bay and search for battery rebuild and you`ll find a few more rebuilders. I`ve used a couple of different ones and have been satisfied with them all .Larry
Re: Cordless drill
flash your battery's
del schisler
>I have brought back to life many batter's by flashing them Any thing from 7.5volt to 18volt the way to do it Ok we will take a 12volt that will not charge or hold just a short time or you can stall it out with your hand Now get a battery source of some kind 2 12 volt car battery's in series = 24 volt Now get some clips and clip on the neg and pos the neg is out to what i will call the back of the battery and the pos is the frount or the long part of the battery Now make sure you get it right Volt meter ??? Put neg on the power source hook on and now take the pos of the power source and strike the pos It will spark Don't worry about that No shock involved at all DON'T leve it hook up You are just arking the pos clip Do this 4 or 5 time's Now unhook all and put battery in charger You will be suprised how well it will work For the 7.5 A 12volt battery would be ok for that one Just do as the other set up's I never had one not work again for a long time This is not a repair But just getting more out of your battery You thought was a thro away good luck
Re: Cordless drill
Bart Goldberg
Bart Goldberg
>It is amazing how much cheaper it it to have my batteries rebuilt versus the cost of new, replacement batteries.
Thanks
Bart
Re: Cordless drill
Never again !
steve mackay
Re: Cordless drill
Sounds crazy, but it can work *LINK*
Grant in Iowa
>Older batteries develop what are called "whiskers" that essentially short out the cells. I copy an article from another forum for your CAREFUL CONSIDERATION:
IF YOU TRY THIS, YOU DO SO AT YOUR OWN PERIL! MAKE SURE TO TAKE SAFETY PRECAUTIONS!!!
If you do not understand these terms or the procedure, DO NOT TRY THIS!
Series/ Parallel
positive/ negative
FWIW,
Grant in Iowa<---ducking to prepare for the onslought of doubters, fear mongers, and safety heads.
Zapping NiCad Battery whiskers
Re: Cordless drill
Re: Sounds crazy, but it can work
Howard Norman
>That is an interesting concept that I had not heard of before. I have a couple 9.6 v batteries for an old Makita drill that I will have to try it out on.
Re: Cordless drill
jesse cloud
>Ditto JL's good words about MTO. My old Bosch batteries run like new, maybe better.
Re: Cordless drill
Gary Evans--Tallassee TN
>Thanks for that link, Grant.
I was just about resolved that I would have to buy some new batteries for my 18V Ryobi. I'll be trying the 24V sparky first.
Gary
Re: Cordless drill
explain ??? Re: Never again !
del schisler
>what do you mean Something happen ??? You mite explain ??? This works Been doing this for a long time You just have to use some common sence when working around car battery's or any battery Not short out They can blow up and cause a lot of hurt
Re: Cordless drill
Mac in Indy
>I have read the link and I am unclear if you do this flashing with the batteries assembled in the battery pack case, using the two exposed terminals, or if you disassemble the pack and flash the batteries only bypassing the non-battery electronic unit that has something to do with charging.
Also how do I determine which of the packs two exposed contacts is negative if it is not marked on the case itself.
Mac
Re: Cordless drill
David Hay @ Denver
>I'll echo the sentiment to rebuild the batteries. I just got my rebuilt batteries back from Primecell and the drill runs as good as new. Before, one battery wouldn't hold a charge at all and the other would die within the hour.
David
Re: Cordless drill
>Hi Mac,
The way I read this link is that you flash the battery pack "as is," no disassembly. You do need to take a voltage meter and make sure which terminal is positive and which is negative on the battery pack.
With my Fluke meter, if I put the negative and positive probes on the wrong terminals, I can read the voltage, but there is a "minus" sign in front of the voltage reading. If you don't have a voltage meter it's going to be difficult to determine the polarity of the battery pack.
You could rig a test light with a diode, but I can't think of any other way offhand to check the polarity. Maybe someone with more electronics than I have will chime in here.
Gary
Re: Cordless drill
Mac in Indy
>I should have thought about the negative voltage reading on the Fluke. I will check it tomorrow! Thanks!
Re: Cordless drill
Larry in NW Ohio
>For me and what common sense has to do with it, I would think the positive would on the top. Any other guesses. Larry
Re: Cordless drill
Joel M. Dibbern-Kramer
>The following is in answer to the question about which leads on the battery are the pos & neg terminals on the battery if there is no clear markings on the battery case.
I would check the tool itself to see which of the contacts on the battery that it is using to make the connection. W/R/T determining which neg & pos terminal, your best friend is a VOM meter.
