Apprenticeship, week 7
Nathan
>This week at the cabinet shop was different, but no less exciting.
On Tuesday, master decided it was time for us to learn to operate selected machines. We started on the bandsaw. The best part was when he showed us how he changes the blades - the saw has 80cm (31.5") wheels, so to get the blade on the top wheel he has to climb up on the table. He has the saw set up really nicely: he didn't even check to see if the blade was running at the front of the tires. He told me that the blades just automatically go where they need to be.
So, after we made some curved cuts (just outside the line), we moved to the edge sander and used it to sand to the line.
Then he set up a small router table on the bench, and we used it to route a bead around the edge of the workpieces.
Anyway, all of this is pretty boring compared to what happened yesterday. On Wednesday my teacher took delivery of a second edge-bander. He uses the first one for regular, straight edge-banding. This second one is specialized for curved workpieces. In order to fit it in the shop, he needed to move a bunch of sheet goods. The other apprentice and I were moving them with him looking on. After awhile the other guy started to get slower and slower and finally master took his place and the two of us were grabbing the sheets and shifting them over a foot or two. I was in between the two "groups" (vertical stacks) of sheets, both stacks leaning in different directions away from eachother. I was bent over making sure the sheet we had just shifted was up tight against the other sheets in the stack. Suddenly I heard a loud noise and looked up - somehow the other stack (luckily it was down to just two or three sheets) started to fall towards me. There was no time to do much. Since I was in a crouching position between the two stacks, the falling sheets hit me in the head and jammed my head into the stationary stack next to me. It was like getting punched in the eye - I had to go the emergency room for stitches and now have a black eye. (See picture.)
Master was really tore up about it and apologized to me profusely, both in private and in front of all the employees. Somehow we got over it and hopefully next week things will be back to normal. The full-time guys had been disgruntled about the sheets being moved farther away from the panel saw. After this "event" they immediately and quickly moved the rest of the sheets without any more grumbling. Now the new machine is in its place and nobody is discussing the matter anymore.
I'd never heard of sheet goods being dangerous, but now I can confirm that when they fall on you, they can definitely cause injury. So... all's well that ends well but be careful out there, everyone.
Also, don't carry them bare-handed because they can cut your hands if they slip and you tighten your grip as they go down. (Of course we use hooks to carry the full-sized sheets, but the partial sheets are easier to carry by hand - until one slips on you and you either cut your hands or crush the corner of the sheet.)
Today I had to go to the same Dr. that stitched my eyebrow for a check-up. His office is right by the shop so I stopped by afterwards and asked master if he had any work - turned out he did, so I stayed for a couple hours finish-sanding some small circular picture-frames that he needed to send out today. The other guys were out doing an installation so the shop was really quiet. Master was setting up the new machine. It was nice just to be there and I'm looking forward to next Tuesday.
One last paragraph - a funny (and related) story. As we were leaving the Dr.'s office, as we were walking through the waiting room, my wife turns to me and says - loud so everyone could hear: "You've got to stop brawling. I'm sick and tired of you looking like this." All the people got these shocked expressions on their faces! (I'm pretty slight of frame and have never been in a fistfight in my life...)
