DC electric a little (OT)
Larry in NW Ohio
>This can be for your Battery power tools. Can anyone tell me a little about the size of DC chargers as in the chargers on a tool that plugs right in the tool. I`m talking about if the tool says it is 3.6 volt what should the output be for the charger. I have a tool that is 3.6 volt and the charger says 5.6 volt 104 mA. Can the charger voltage be somewhat higher than the tool voltage without damage. At least I think it`s the right charger, it`s the only one that`ll plug in the tool and is close to the right voltage. I hope I explained this clear enough. I`m not very good at explaing things very well. Thank You Larry
Re: DC electric a little (OT)
Dale Stansbery
>The charge voltage has to be higher than the battery voltage to charge the battery, other wise it would be a stand off. Your 12 volt car battery gets between 13-15 volts from the car charging system. I don't know if there's any set rule, but the manufacturer of a specific battery would have the specs.
