Re: Compressed air with Pex?
>Paul,
you're in for some research as you've got several issues to address.
1. What is the burst profile? When PVC breaks under pressure, it shatters into sharp shards that can kill. The manufacturer is likely your best source of information on this point. Your piping should actually exceed the rating on your compressor's tank. Even type M copper will take more than 400psi, I use type L copper for air lines.
2. While PEX is rated for 100psi for water, gas pressure limits may be much less because water molecules are much larger than air. Fittings and joints may easily leak even if the tubing itself will hold. Again, the MFG'R is your info-point.
3. While the material is not overly expensive, the tools are. One contractor friend spent $400 for the compression tool to put fittings on the tube-ends. Unless you can find a rental unit, that's getting pricey for a tool that won't see much use after the initial project.
4. There are new flexible lines used for fuel gas, but they are expensive and, again, the joining tools are expensive as well.
Good Luck.
