A55 Smoothing Plane
Delta Planer 22-580
Delta Planer 22-580
Delta Planer 22-580
Dave Winters
>This little planer has developed feeding problems. Seems like when I'm planing stock, the feed rollers feed and stop every 6 inches, then we have to push, and then get another 6 inches and another stop.....
Strange. When there's no load, we can see the roller turning just fine.
Anybody have similar problems?
Thanks in advance--
Dave
Re: Delta Planer 22-580
Ark
>It could be your rollers need to be cleaned. I had a similar issue with my Jet.
Jerry Samsen
>I have the same planer and this happens occasionally to me. I'm also interested to hear what others have to say.
BTW, I does not always happen. Sometimes lightening up the cut helps. Sometimes, if narrow enough, I move to a different part of the 13" bed. Seems to happen to some species but not others. Rarely on cherry but occasionally on maple / oak.
It could be dirty rollers but I have tried cleaning and that did not seem to do anything. I've tried waxing the bed, that did not do much either.
Larry in NW Ohio
>Neither of you said anything about looking at the rollers when the board is being feed. Are the rollers turning when the board stops, whenthe board is being feed and is under the rollers and it stops, look at the rollers anf see if they have stopped then, if so then you have a problem with the feed shaft or the sprocketor pulleythat is feeding the rollers. If that is not it and you cleaned the bed and rollers the next thing I can think of is, are the blades sharp, that is just about all that will stop feeding. Good Luck. Larry
Stephen Kirk in Quakertown, PA
>I have the Delta planer and I get this problem pretty regularly. Every time, I clean the rollers, wax the bed and all is fine. I use some soapy water and a little sponge to clean the rollers. You have to cycle the machine in order to clean all of the rollers surface. I haven't changed the blades in a while, but they can be an issue. If the knives are dull you should also be seeing lots of tear out.
