Shop heat question - free standing radiator
Stephen Kirk in Quakertown PA
>So, my current heater, an old kerosene stove, has about given up on me. I want to replace it with a good radiant style heater without an open flame (had the kerosene, but was always a bit wary of fire hazard). The free standing, electric, oil filled radiators look pretty good and seem to put out quite a bit of heat. Has anybody used one like this before? Do they work well? Do they hit the electric bill hard?
For reference, I'm in a 1 1/2 car garage, insulated but with a big door and concrete floors. Garage doesn't usually drop below about 40 deg on even the coldest of days. I'm comfortable working in a 60-65 deg shop, doesn't need to be in the 70s.
Re: Shop heat question - free standing radiator
steve mackay
>I got one of the oil filled, plug in radiators for my barracks room in germany one year. I was actually impressed with it. Did a good job. From then on it bounced back and forth with me through three tours. I could run extension cord out to a gaurd shack and be toasty during shifts also so its pretty rugged, transportable and GI proof. Really don't know if it could heat up a large shop though.
Bill Earl
>The oil filled electrics heat a small room nicely. But I don't think it will be enough to heat your shop as you describe it.
The concrete floor is a huge heat-sink and you will probably lose a fair amount through the garage door too. You might be better off with an overhead radient heater to warm you up instead of the air.
Clint Searl
Clint Searl
>I used a radiant propane reflective heater that screws to a 20# tank in my garage shop for many years. Very effective with a fan behind it and still works well. It's yours in exchange for a donation to WC.
Clint
Frank Orfanello
>I've used those oil filled heaters and they ar not bad in the right situation. I don't think your situation is right. it's too big an area and too big a heat sink with your floor.
Larry in NW Ohio
>Clint If Stephen doesn`t want it, let me know I may be interested. Thanjk You Larry
Re: Shop heat question - free standing radiator---
Stephen Kirk in Quakertown, Pa------WebKitFormBoun
>Hmmm, how long do you run on a tank?
------WebKitFormBoundaryz+kg+IE1vFbGcujX
Ronald
>i use one they work great!!!
Yep, they are wonderful for that.
Michael Dresdner
>My shop is a two car garage, two big garage doors, concrete floor, minimal insulation. I have three oil filled electric heaters. They warm the place in about an hour, after which one is more than enough to keep it comfortable, and often I have to turn it off completely after a few hours. I can even spray, intermittently, and still keep warm enough.
