Veritas - Innovation in Tools
Outdoor Light Fixture
howard
>I need to rewire an outdoor light fixture(just the wire in the fixture). I purchsaed 16/2 lampcord at Depot - it will be fully enclosed in the fixture, but wasn't sure if this type of wire was ok ffor cold winters and hot summers. Thanks.
Re: Outdoor Light Fixture
Larry in NW Ohio
>Howard When I wire something I go by the breaker amps, which in your case I would think it would 15 amps if not 20 amps, in which case the wire should be #12 for 20 amps or #14 for 15 amps. If you don`t the wire will burn before the breaker opens. Larry
GalenV in Iowa
>16 gauge stranded copper wire is fine for wire within a fixture. Don't use "lamp cord wiring" as it is not suitable for outdoor, moisture, heat and cold.
Use type TFFN, TFN or MTW with thermopalstic (PVC with nylon jacket) insulation as it is suitable for your application and Code. The wire size is not controlled by the circuit breaker even on outdoor lighting.
Galen
JMOHNIKE@PSNW.COM
>Check the wire on the fixture. I have had problems in the past with fixtures that came equipted with aluminum wire, when I connected them to stranded copper wire. In time the connection failed (Corrosion)I replaced the equipted aluminum in the fixture with copper, and try to do this with any new fixture I install, keep in mind this does void any warranty, but I feel it is safer, (maybe not) but I am not an electrician. Use approved outdoor wire the cost diff. is not that much.
Joe
Thanks Guys.....
howard
>I am going to head over to my local lighting fixture shop where they have supplies and I'll get the correct wire there. Thanks for all your help.
