Pride in work
Pride in work
Pride in work
Chuck in ND
>A couple weeks ago we had a heating contractor come put a aluminum chimney liner in our brick chimney ( gas furnace and water heater. We decdided that we would give new relation at shot at it. First I will say that when I called the company I did not ask or expect a relation discount, as long as they do a good job and it isn't way above the going rate is all I care about. So two guys show up after only guesstimating over the phone what they need to complete the job. In the middle of the job they takeoff for about an hour to go get some 3" vent for the water heater, while they were gone I red the installation manual. Right away I noticed that they didn't install a sheet metal sleeve that came with the kit that goes where the liner enters the Chimney in the basement, I also noticed that the kit has a warrantee with a place to write down when it was installed, by whom it was installed, the kit number, etc. When they came back I asked about the sleeve and was told it wasn't neccesary. Then I asked if I could have the installation manual for warrantee purposes, I was told that it was allready thrown into the box and in the back of the truck. After they were done with the job I look up at the vent cover ontop of the chimney which has a square clay liner sticking out of the brick about 6" that the cover was installed ontop of. The vent cover is round and attached to a flat piece of tin that I'm guessing was around 18" X 18". When the boss installed the vent cover he sniped the corners off, siliconed it to the clay liner and then what apears to me he did was push the sheet metal around the sides of the clay liner by hand and not tight against the sides of the clay liner. One side overlaped 4", another at 3", another at 1" and the other at 1 1/2". It looked like crap. I ended haveing to go up there after they left and cut each side equall, then attempted to get the sides tighter to the clay liner. I also had to mortar in the 3" hole in the chimney where the water heater use to enter the chimney, and around the opening where they installed the new liner. Now heres the delema, what are the chances of finding anyone that would of done a better job then they did nowdays ? It amazes me. We haven't got the bill yet so I haven't decided weather I'm going to make a few suggestions to them or not.
Re: Pride in work
Re: Pride in work
Bruce, a MN Galoot
>Chuck,
will you send me the name of that outfit by email? My son in Bis needs some work done and I need to warn him.
Thanks.
Bruce
Re: Pride in work
Re: Pride in work
>Good Morning Chuck,
That is a terrible story. I've had clowns like that a couple times and would never have them in my house again. I do remember on an other occasion, a crew left off a piece of flashing from the front roofline and it looked terrible. they gave me a song and dance about it, so I called their company, expressed my dissatisfaction, and then paid only 80% of the bill. They got the balance when I was satisfied.
George
Re: Pride in work
Re: Pride in work
Fred Davis
>Chuck ,
do yourself and others a favor in your area and have the Building department inspect the job.
Even if you have to buy a Mechanical permit , it will be well worth the effort.
One or two jobs like that will cause the Building official to flag the contractor which I seriously doubt is licensed.
Then have a reputable contractor redo it to specs and deduct his fee from the first one.
Tha is a perfectly legal and acceptable way of doing business, we call it a "back charge" in the building industry.
FredD
Re: Pride in work
The other side of the coin
Hank Knight
>Occasionally you find someone who actually does care about his work. LOML and I had been trying to get some remodeling work done on our house for months. I spoke to four separate contractors, two of whom never bothered to show up for an appointment to look at the work; one showed up, took measurements but never submitted an estimate, even after several telephone requests; and the last one actually gave me an estimate, but never showed up to do the work after I authorized him to start. I gave up on the project out of sheer disgust.
Back in the Summer my wife came to me with the name of a contractor a friend of hers had recommended. The other contractors had also been recommended by friends, so I was less than enthusiastic. But we called and made an appointment. The guy came, looked at the work and gave me an estimate. The estimate looked reasonable, and, after some minor negotiation, we agreed on the scope of the work and a price. The guy said he could start the next week. I held my breath.
The contractor's crew showed up as promised and started the work. I continued to hold my breath. After several days, it bacame apparent that his crew was serious about their work. Two of them were finish carpenters and knew what they were doing. They showed up early and left late. I watched closely and was happy with what they did. To make a long story not quite so long, the contractor finished the work on time, UNDER his estimated cost and I have absolutely no complaints about his work, it was all top notch. He completed his punch list quickly and I paid him in full the same day. I was, and continue to be, amazed and delighted to know that there are still contractors who take pride in what they do.
An episode during the project illustrates the original point of this thread. One afternoon the plumbing subcontractor was sweating on some copper fittings in the upstairs bathroom. Suddenly my wife heard raised voices and the plumber and his helper came running downstairs. They had set the insulation in the wall on fire. They had turned off the water at the street main so they had nothing to douse the flames with - - DUH!. Fortunately, we had a fire extinguisher handy that took care of the problem before it got out of hand. As it turned out, the plumber didn't even have a fire extinguisher in his truck. My contractor fired him on the spot.
Don't give up on our building professionals just yet.
Hank
Re: Pride in work
Re: The other side of the coin
Larry in NW Ohio
>I have a contractor that I always use. We use to work at the same place before they shut down. I got to know him pretty good. I always go to him when I can`t do what I want done. He is the only one I even go to in this area. There isn`t anyother contractor that I would even let on my property, I wouldn`t trust any of them. But this guy I can trust, I tell him what I want, he gives me an estiment and and we go from there. I know I can trust him. Larry
