Need Dryer Fitting (OT)
Larry in NW Ohio
>Trying to put my SIL`s and daughter`s cloths dryer. Or course the contractors put the outlet in the wall and didn`t ask where they should put it. They put it right up to the wall and now I have to try and run exhaust pipe out the side. What would really help is if I could find a close wall fitting that is basically a street 90 degree elbow. It`s just about like the telescope thingy but it comes out of the dryer and goes 90 degrees and goes about a foot and has a 4" outlet. Sears has them but they need to order them and don`t know how long it`ll take. Does anyone know where I could get one? TIA Larry
Re: Need Dryer Fitting (OT)
A Suggestion
>I would look up HVAC supply houses in your area that handle metal ductwork. They may call it an outlet plenum, and if they don't have one in stock, they can most likely make one for you.
del schisler
>home depot has them Maybe lowe's also it is a flat unit with a telescopeing piece with the 4" in and out or 3" out don't remember but it is for dryer's they are ment for close up to the wall use
Walt Smith
>I think they're called a periscope. A good hardware store will have them. The borgs should, they sell appliances. They do telescope but will likely be too long. You just cut 'em to fit. The one I bought didn't fit all that tight so after I got it cut to length I taped the two halves together with metallic tape.
