12 parks planer... input rollerfree wheeling
Frank on Chestnut Hil
>Gentlemen,
I have had my Parks planer ( serial number 36xxx) for many years. Today I experienced a first. A small piece of pine would not feed.
The grooved input roller was not pulling the wood into the planer.
I opened the drive case and just happened to see a set screw on the A-4 12 tooth input sprocket gear. This gear is driven and it drives a chain that drives the grooved in feed shaft. I tightened the set screw and every thing seems OK.
I looked at the exploded view of the drive system but am not sure if there is a key below this set screw of if the set screw just drives in against its shaft.
Has anyone had their gear box apart and can verify that it is only the set screw that transfers the rotating force???
Thanks in advance,
Frank G
Re: 12 parks planer... input rollerfree wheeling
>You might also raise this question on the Old Woodworking Machines forum; you're likely to get a prompt reply there; linky below.
Thanks, I Will ......
Re: 12 parks planer... input rollerfree wheeling *LINK*
Robin Corell in Atascadero CA
>There is also a wiki file over at OWWM and one of the files has pictures of every single part. I found this extremely helpful.
Robin
picures of Parks parts
