Apprenticeship, cont'd
Nathan
>My apprenticeship at the architectural woodworking shop is continuing apace. At this particular shop, so far, I've seen them making cabinets out of melamine and veneered particle board, painted cabinets out of MDF, doors and windows out of spruce, and a bunch of other stuff. Today I noticed they started machining some oak for a church-bell mounting and they are also building a big curved caul for making bent-lam shelving. I only go in two days a week so I don't see everything they do.
Now, I'm not directly involved in any of this stuff - except as a "fly on the wall". The owner is a master woodworker and a great guy - I'm really lucky. Like I mentioned before, he has me working at the bench with hand tools exclusively.
So far, I've learned how to:
- sharpen dovetail saws and frame saw blades by hand using triangular files
- grind, sharpen and hone chisels (freehand)
- grind, sharpen and hone plane irons (freehand)
- rip cut to a line using a frame saw
- cross cut to a pencil line using the dovetail saw, leaving the pencil line still visible after finishing the cut
- clean up frame saw rip cuts using a wood jointer plane
- cut mortises with standard chisels
- clean up roughsawn lumber using the jointer plane
- plane edges of boards straight and square (freehand)
Today he said the next topic is going to be joinery.
You'll notice he has me doing everything by hand and also freehand - so no tablesaw use, no honing guides, no shooting boards. For example, he had me do rip cuts with the frame saw for two days straight. Today I spent the entire day going back and forth between the bench and the sharpening station with the plane iron. Paradoxically, learning to sharpen and hone the iron itself was actually fairly easy once my teacher showed me the technique. What I really struggled with was the cap iron. It took me forever to get it ground to the correct angle (although I found that even with a substandard grind on the cap iron, the plane still cuts nicely as long as the main iron is sharp).
My teacher doesn't spend much time at my bench. He'll come up and give me an assignment (along with the materials and tools I need), briefly demonstrate the technique, and then let me struggle with it for hours and hours. A couple times a day he'll stop by and point out what I'm doing wrong.
The chisels and plane irons he gave me were all either really dull or improperly sharpened. Getting them working was a real learning experience for me. First I spent hours trying to joint a board with a dull iron. I planed it down to half its former width and made a huge pile of shavings but could never get it straight. I got pretty frustrated with that. Then my teacher finally came, took one swipe with the plane and said: hone the iron. So I did that and suddenly it became possible to joint the edge properly.
Sorry I can't really explain all the learning experiences I'm having there but anyone who has been through something similar knows what I'm talking about. What incredible luck to have this opportunity. After having spent years trying unsuccessfully to learn to work wood with machines, this is like coming out of a dark cave into broad daylight.
This week I ordered a real bench for my home shop. It should be delivered in late November or early December. I found a guy who makes them and he's going to deliver it in person and help me assemble it. He lacquers them as standard, but I went with unfinished and will finish myself with linseed oil. My teacher is not very eloquent and doesn't spend much time talking, but he did describe the shop where he did his apprenticeship many years ago. He said his teachers basically lived their entire lives at their bench, working 16-hour days, and did all their work by hand. Even though they didn't have any machines, he said, they were very productive. Today after I finally learned how to joint that board he said I'd need to do the same procedure a couple hundred times before I really mastered it.
Next week he said we're going to start joinery. The first joint he wants me to do is the bridle joint.
