We value your privacy.
>I am the original owner of a 1996 vintage Powermatic 66 tablesaw. Recently pulled off the top, cleaned all parts I could reach with a toothbrush, etc. and lubed per an article on the subject in Fine Woodworking a few years back. It still makes sort of a "grinding" or "rumbling" noise while running but, otherwise seems to cut just fine. I was thinking it should sound more like a swoosh or, car engine idle, as on The New Yankee Workshop. Any suggestions on what to look for or try next?
>Try taking the belts off and turning the blade and see if that is rumbling if so it`s probably bearings. To get the blade turning faster, turn the blade around, in other words backwards, and take an air hose and blow air on the teeth so it goes the right way. If it doesn`t come from there try the motor. That is the only thing I can think of. Good luck. Larry
>I have a 1997 Delta Uni Saw which started making rumbling noises. It finally started smoking one day. It was the bearings on the arbor. Called the local authorized Delta service center, and a tech came 2 days later and installed two new bearings. Cost-$220. But there is a warranty on parts and labor and He was in and out in an hour or so. I would still be working on it.
>Your description surely sounds like worn or loose bearings on the arbor.
Now, you did not have something lying on the top that was rattling, did you? My miter gauge sounds just like a worn bearing when it is on the side table of the saw.
>Check by rotating by hand & belt off (& cord unplugged):
1)noise from the arbor. Should rotate easily & smoothly with no noise or grinding feeling transferred to your fingers.
2)same test on the motor.
3)Are pulley set screws tight & intact? If so, loosen them and check any wobble between the pulley and shafts. A pulley who's fit to the shaft, even with tight set screws, could wobble under the tension of the belt. Die cast pulleys are notorious for wearing. Replace with cast iron or turned steel.
4)Slowly rotate the arbor and motor, carefully looking at the pulley faces (with the aid of a bright light)for any irregularities. A pulley with a polished/rough or dented area will cause the belt to hop each revolution.
5)Inspect your belt. If there were several times where the blade got stuck in a board and the motor continued to run, the motor pulley would have polished or wore the belt. Cheaper "wrapped" belts have a seam that will cause some vibration. Slightly more expensive "cut" belts have no seam and run fine. Segmented belts are cool, but hide other vibration issues that should be corrected first.
If you are slightly mechanically inclinded, arbor bearings are frequently commodity items that can be purchased anywhere once the numbers are learned from your bearings and can be replaced relatively easily. Cost me about $20 to do my JET saw, and we did my neighbor's Delta for about the same cost. Bout an hour to take apart, and a little more to reassemble, as allignments now need to be rechecked.
