Template
Template
Template
Doug Ridley
>How do I make a template that I can follow with a router and get a perfect curvature? The racks I have made such as the one pictured have too many little dipsy doodles in them to suit me. I need a template that is perfect so I can bandsaw my plaque close and finish it nice and smooth with a router following the template. But I can't figure out how to get the template right. I sure would appreciate some instruction.
Doug
Re: Template
Re: Template
Grant Wilkinson
>FWIW, for pieces like the in your pic, I take a piece of construction paper folded in two and draw half of the pattern on it. Once it's cut out and opened up, the two halves are perfectly symmetrical. I transfer this to a piece of masonite, cut it out and sand it so that it exactly on the line. Then, as you say, I use that pattern with a pattern following bit in my router.
Re: Template
Re: Template
>I agree with Grant.
I can't think of the names right now but there are two types of bits for this. One has the bearing at the top and the other has it at the bottom. A pattern bit and a ?????
The quality of the bit and bearing make a big difference. If you use a bit where the cutter is half inch in diameter and the bearing is on top and the shank is a 1/4", that means the bearing has to be half inch in diameter with a 1/4" hole. Leads to a very thin race and very small bearings in the race. Might be better to use a 5/8 or 3/4 cutter diameter and a sturdier bearing.
Also, the quality of the pattern is very important. Masonite or hard board makes a pretty good pattern for something where you are going to make a few pieces. Wood or even plywood has variable hardness and even if you are careful making the pattern, the bearing will track into the soft spots and create dips in your piece. So, use a hard consistent material for you pattern. Plastic such as Plexiglas might be better than hardboard. Aluminum would be better still if you plan to make dozens of pieces.
For a symmetrical piece, I make a pattern of the pattern. I make up a half of the pattern out of something like hardboard. Use it to cut one half of the actual pattern, flip it and cut the other half.
Of course, the end piece is only as good as the pattern. Spend time at the sanding drum perfecting the pattern. On hardboard I had hardened the edge of the pattern with Cyanoacrylate glue. once the edge of the pattern is finished, coat it with thin CA and let it harden. I have also repaired mangled patterns.
Its also a good Idea to make the pattern longer than the piece so that you can start routing off the end of your piece and work into it. The Bearing on the shaft spins and the pattern brings it to a halt. The bearing may wear into the pattern while it is screeching to a halt. Those little divots will show up in the piece. So start routing off the end of the piece so the divots won't be in the piece.
Re: Template
Re: Template
Doug Ridley
>Thanks.My whole problem is getting the template exactly right in the first place.
Re: Template
Re: Template
Gary Camp, Bend, Oregon
>I would take a full sheet of melamine and layout the curve I wanted with a piece of 1 X 1/4". Then I would pick a few points on the curve and guess and by gosh the radius (The math wizards could could use the chord length and height to figure this out I'm sure) I suppose you could also use a CAD program to figure the radius with the same givens. Then I would use my BIG circle cutting guide to (a piece of plex drilled to match my router base and about 4 ft long to cut out the template
glc
Re: Template
Re: Template
William H. Falberg
>If I understand correctly, you're asking how to lay out radii and link them symmetrically. I do it on the floor with nails and picture-hanging wire, plumbers tape, or chain; anything that can't stretch when you pull it tight. Keep the wire close to the bases of the centers and your pencil after you lay it out geometrically. You'll have to nail down your template as you do this. You need a smooth surface to swing your wire over/around the arcs. Locating the centers can be tricky and involves some geometry but the trick to accuracy is fine lines and careful execution. Patience is a plus. I lay out the radii then draw straight lnes to link them.
Re: Template
Bit of a different approach
doug f, san clemente, ca
>Doug - when I need this kind of layout I toss out the "radius is this" and the "radius is that." I get a big sheet of butcher paper and a Sharpie and lay out one half of the piece with a curve that pleases my eye. Changes are easy to make. You would be amazed how easily your eye picks up bumps, lumps and curves that don't look right.
When I have half of the outline that I like, I just cut on a center line and flip the paper over and draw the other side. Cut out the completed pattern and copy it to some 3/8" MDO, baltic birch ply, or other template material.
Cut it out (band saw, probably) and patiently "fair" the curve on a spindle sander. (Very important step!)
Ta, Da! Perfectly symmetrical, pleasing curves on a template you can use again and again.
Works for me. YMMV.
Have fun with your project.
Doug
Re: Template
Re: Template
Fred Davis
>You need Ken Horner's MORE ESSENTIAL Facts,Formulas and Shortcuts.
For your needs you will find all revealed on pages 323 and 324 in the "Chapter ,Shaping Wood wiht Patterns and Templates" and Curved Cuts in that Chapter subtitled Band Saw Templates.
If you plan on serious woodworking and find yourself stumped this book will give you priceless information seldom found anywhere else , much less in a format that is easily understood.
Amazon.com is the plce to find it for the best price.
FredD
Re: Template
French curve
Ed Mulligan, Cape Cod
>To draw smooth curves, buy some french curves from a drafting supply house. They come in different sizes and shapes.
To use, make a rough sketch of the shape you want. Select a small part of the sketch. Move the french curve over the sketch until you find a section that matches the sketch. Run a pencil along the edge of the curve.
Re: Template
Re: French curve
>Good Evening Ed,
I'd be lost without my set of French curves, which initially were inspired by Bridgit Bordeau. I've had and used them fgor a decade or more. Well worth the investment.
George
Re: Template
Re: Template
Doug Ridley
>Some good ideas here. I'll try some of them out tomorrow and let you know how it comes out. Thanks, Doug
Re: Template
Re: Template
Lee Valley curve drawing thingy
Bill Tindall, E.TN
>II struggle with these same issues until I got over being cheap and bought the symmetric and asymmetric curve drawing thingys from Lee Valley. I have used them a lot once I owned them.
The problem with french curves, and I own about every style made, is that they are too small for many woodworking needs. It gets tedious and imprecise assembling the curved segments to make a big curve like you need. Ships curves are better (bigger) but costly to buy.
Re: Template
Re: Lee Valley curve drawing thingy
Jesse Cloud
>Lots of good advice. I would add that using MDF for the template is good because it sands well and a scraper works well on it. Work patiently until you think it is dead smooth - close your eyes and run your finger on the curve - your sense of touch is amazingly sensitive. If you make a mistake and take away too much, build it back with a little Bondo - which also sands well.
When routing the workpiece with a flush trim bit, its important to keep the bit dead vertical.
And BTW, when you get a template you really like, the first thing you should do is make a copy!!
Re: Template
Re: French curve
Art Liebeskind
>Colonel,
I too have a set of the Bardot inspired curves. I find that they only work on the rear of my piece.
Art Liebeskind
Re: Template
Re: Template
Doug Ridley
>Hey Gary, did you ever get any snow?
My daughter lives in Bend so I already know the answer. How 'bout some pics?
Re: Template
You making coat racks for giants?
>That room, with the blue walls and brown carpet, looks to be about 15' - 20' wide.
So what are you doing building coat racks that are 20 feet wide? Been climbing any beanstalks recently?
Happy Woodworking!
Re: Template
Re: You making coat racks for giants?
Doug Ridley
>Well, Mark I'm a pretty big guy. I would have made it a little bigger but I couldn't figure out how to move the walls out.
Re: Template
Re: Template
Gary Camp Bend, Oregon
>we had 2-4 inches yesterday, melting now 70 by friday, Trees with leaves aren't meant to take snowloads, didn't get any pictures
Re: Template
how I make curved templates
Robin Corell in Atascadero CA
>I kind of specialize in making curves. Most all of my designs have curves. I do things a bit differently than most wood workers due to my back ground as a patternmaker. For me making a curve is very fast and easy.
I start by using a set of trammels to strike an arc on a piece of scrap. I prefer 1/4" baltic birch ply but I more often use 1/4" thick solid stock. The trammels are always kept handily mounted on a beam and hanging on the wall. I rough cut the curve on my band saw and then sand to the line on my stationary disc sander. I lable the newly made template with the radius and drill a hole near one end so it can hang on the wall with all my other templates.
I can then develop a line like you are wanting by placing two templates so they are on opposite sides of the line and touch. this creates a nice smooth transition. You can use templates that are a single radius to develope the template you want to use for routing your coat rack and then cut it out by sanding to the line on a combination of stationary disc and osscilating spindle sanders.
Geting a nice smooth curved line on a disc or spindle sander is a skill but, with minimal practice it is not too dificult to get acceptable results.
Robin
Re: Template
Re: Template
AZ, Colorado Springs
>... flush trim bit (that's one with the bearing on the top)
Re: Template
Re: Template
Fred Davis
>or bottom
FredD
