Wood Burning Stove?? *LINK*
>Well recently I posted about electric heaters. A recap....I am taking over space in my adjoining garage as part time extra shop space. Since I posted I had the idea of putting a wood burning stove in the shop (properly vented of course). I could burn my wood scraps for fuel. Below is a link to a stove I found. Looks simple and good but it has no blower. How important would a blower really be? Thoughts on wood stoves in shops?
TIA
Wood Stove
Re: Wood Burning Stove?? *LINK*
John Veerkamp, Western Mo
>As grant said, check with your Insurance company first. A blower is not necessary, but a small fan of some sort will help distribute the heat more evenly. Otherwise you will have more variations between the stove area and pockets farther away. A ceiling fan blowing up or even a small circulating fan will do a good job. Doesn't take much, just something to stir the air gently.
John who's heated with wood for 32 years.
Gary Camp, Bend, Oregon
>Other than the fact that a wood stove won't maintain heat in the space I LOVE the wood stove in my shop. My stove is a nice homemade welded steel stove, that looks professionally done (not by me). It will take my shop, (unattached, fairly well insulated, 24 X 48 X 9-1/2) to shirt sleeve comfort with outside temps near zero in about 30 minutes. When it is really cold I just build a fire in the shop every evening for a couple of hours. That keeps things above freezing, I also have a spare fridge and freezer that help a bit. The side benefit, no one sees the mistakes and the scrap pile goes away.
glc
Marvin Horn
>We've used wood as our primary heat in the house for over 20 years. I use electric and propane in the shop. If you add up all the dimensions and required clearances you'll have to devote about 30 square feet to any wood stove. Just don't have that available in my space challanged shop. If you go with a "modern" stove with heat sheilds, etc you lose the advantage of fast heat-up.
My cut-offs and scraps supply about half of my kindling supply so unless you're a full time woodworker don't expect to heat your shop for free.
Jim Shaver
>Are you sure it's cheap enough?
A fan in a shop is a dust mover....
Jim
Yonak
>The ad says, "Not available in CA & WA." I wonder if they have codes that are too strict for this bargain stove. Also, as John says, a fan to keep the air circulating is a good idea. Just don't blow directly on the vent pipe as it lowers the temperature of it and could tend to increase the incidence of creosote.
Also erases mistakes
Lee Schierer - McKean, PA
>You can also destroy the evidence should you ever make a mistake.
My Dad had a wood stove to heat his shop. It did a good job but took a while to get the heat to the other end of the shop, so he mounted a small fan a couple of feet above and just behind the stove to blow the heat the length of the shop. This heated the shop up more quickly and uniformly.
Lee
Dale Lenz
Dale Lenz
>Been heating my shop with an Ashley wood heater since it was built, 800 sq. ft. A county boy with more common sense than a whole herd of city city folk, including me. Told me about blowing air across a wood heater to improve the heat, that is to dissipate the heat off the cast-iron: Difference between night and day.
Your wood scrap will make good kindling, me think you will need to buy/have firewood. I use about a rick of wood per winter. You might need more due to your location. Remember to use seasoned wood, 6 mo. old plus ideally, better for your heater's flue and more heat for you.
GalenV in Iowa
>I agree with Dale that scrap wood is kindling and not main firewood.
I had to be very careful of the amount of scrap wood I burned at any one time as it burns too fast and hot for the Vermont Casting stove I had.
Galen
steve mackay
>I've had two for 'bout ten years. Like 'em both. Air movement does help though. I use a smaller fan. I keep trying to save up for one of those heat-sink thingies though but they look kinda pricey. I've had many, many folks lecture me about how inefficient wood burners are but I have always managed to hunt up enough un-treated, un-painted scrap for nuth'n to feed them for the winter. Everything I burn was headed for the dump so I figure, while I'm not a true Greenie, I'm not wasting either. And saveing my gas bill in the bargan. Be prepared to be lectured to about your polution "footprint" though. :)
Darn right about the pollution!
Bill Howatt
Brian in Sandusky, OH
>I heat 1000 sq feet with both a propane furnace, as well as a woodburner.
I use the furnace to kick-start the heat quickly, and then the woodburner to maintain. The furnace usually only runs 15 minutes a day or so.
When it's really super-cold. I usually throw in a log at the end of the day just to keep things from freezing.
Some people mentioned that the stove looks cheap and probably isn't very energy efficient.
Well, we are heating garages, right? There's leaks all around my garage doors that I can't control.
If I were going to buy a woodburner for my home, then I would indeed be concerned about energy efficiency, and probably spend good money.
But for a garage, go cheap, and who cares about efficiency? Your going to lose heat through small gaps and the innate issues that garage doors have, regardless.
Low value stove
Tom Dunlap
>When I bought a house one of those stoves was in the shop. I fired it up in late summer for a test run. The thing had so many leaks where the panels came together there was no need for a draft control. It was scary!
I made a stove from a water heater tank that was vertical to save space and the extra volume up top made for a smoke chamber to scavenge heat.
Sure, wood stoves may create some air pollution at the point of generation. But...if you look at wood heat, especially from scrap wood, and compare cradle to grave pollution, wood stoves come out pretty low. Nuke power creates waste and pollution at every step of the way.
Tommy, Tommy, Tommy....
Jennifer@Indy.USA
>I just sold my Vermont Casting wood stove on Craigs list!
Re: Tommy, Tommy, Tommy....
Jim Shaver
>what a shame.......
Jennifer@Indy.USA
>It's a good thing. When I replaced the 22 year old furnace I discovered that the house stays so comfortable that I never had to light a fire to even temps out, and keep my bill down. More floor space and not worrying about a burning fire when we leave the house is nice too. I also found that when shopping around for a better price on home owners insurance that nobody would even talk to me knowing I had a wood stove that was installed more than 20 years ago. It's a good thing all around.
Jen
Jim Shaver
>and Tommy's just too cheap to pay for that stove anyway, it would have easily been $2k, right, that number seems to ring a bell for some reason...
Thanks All!
>Some great info and advice. Much appreciated folks!
Tom
Lee Brubaker
>Somehow I'm unable to get my mind around anyone burning hardwood scrap/cutoffs when so many children of needy families go through Christmas without toys.
I use a double garage as a hobby wood workshop. I heat it with a 45,000 btu gas radiant tube heater(we get -30C winter weather). No moving parts or fan to blow dust around & so efficient I don't notice it on my gas bills.It may seem a little pricey at purchase time but a youngish(less than 60 yr old)woodworker would find it very cheap over the long run. I'm older than that but rich (ha) & spoiled.
Lee
Re: Low value stove
Fred Davis
>Efficiency of wood stoves depends on what stove your using .
In our case we have a wood fired boiler with water jacket that keeps the cast steel box no warmer then the cats like and the hot water is pumped through the floor slab in zones that keep the house toasty in Kansas wintertime .
The shop keeps the kindling supple overflowed and the Osage Orange Hedge is split and delivered for about two hundred dollars per season.
This season after a afternoon of spliting with a friend helping , we will not need to buy any , enough fell down last year like Hackberry and Chinese Elm to augment wha was left over from last years Hedge.
The cost of the electricity that runs the water pump is very small.
So , since the heat this winter is free, I guess one could say the efficiency rates pretty high .
FredD
