Totally OT for car nuts ;-)
Dan Donaldson
>A few interesting items:
One top fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of stock cars at the Daytona 500.
It takes just 15/100ths of a second for all 6,000+ horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture of nitro methane, the flame front temperature measures 7,050 deg F.
Nitro methane burns yellow... The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4. 5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have completed reading this sentence.
Top fuel engines turn approximately 540 revolutions from light to light! Including the burnout, the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
The current top fuel dragster elapsed time record is 4.428 seconds for the quarter mile (11/12/06, Tony Schumacher, at Pomona , CA). The top speed record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony Schumacher, at Hebron , OH ).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and pass the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment.
The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you
200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
...... and that my friend, is ACCELERATION!
Re: Totally OT for car nuts ;-)
Dick Coers
>Love those specs and the machines. I get a kick out of the fact that the fuel line running from the tank is over 2" in diameter, and the fuel pump flows over 60 gpm.
When Will They Start Using Hybrids?
Ken Oakley-Sunny St. Cloud, Fla.
So What? *LINK*
>What's the big deal? I used to ride to school going that fast....
Tommy Going To School
That's why Soccer Moms hate me. ;-)
3rd Brake light is burnt out, tsk tsk tsk
Jim Shaver
Used to make cams for those....
Tony - Memphis
>I used to work at Comp Cams as an engineer. We did a lot of cams for those guys. I remember a few tales of motors that "hydraulic'ed." The combustion chambers are small and they fill up with fuel and boom - a piston can't compress a fluid, so something has to go! Thye wen't through a lot of cams too. Mostly rollers, but some of the guys actually used flat tappets. That's been around 13 years ago, so thigns may have changed a bit. That nitro fuel realyl got to me. I couldn't stand to be around it. Always shocked me to see the guys standing around inhaling those fumes - whew!
Tony
Re: 3rd Brake light is burnt out, tsk tsk tsk
Mark Nowicki
>This video should stop my girls from complaining about their brothers farting in the back seat. He is probably just as grateful for the power flip out rear windows as I am.
Mark
Another Useless Fact...
Robby Wright in San Marcos, CA
>A Top Fuel engine's fuel pumps require 800 HP to power them.
I once saw a show on the fuel system that showed one-half of the fuel system, with four injectors going into the intake ports and four into the top of the supercharger. They had a pair of fuel pumps being driven by a 25 HP motor and used water to represent the fuel. The water was just pouring out of the injectors. The announcer asked: "So that is what it looks like when the engine is at full throttle?" The fuel system expert said: "No. That is idle. We don't have enough power to get full throttle". Unreal. I miss my days of racing...
Robby W.
And to think......
>....the drivers used to sit BEHIND the engines! T.
Re: Cam question, Tony
DaleLenz
>Back in the late 60's and early 70's gearheads talked about 3/4 and full race cams. I put a 3/4 race cam in my muscle car. Now "new" folks ask me what exactly did the 3/4 and full race mean?. Guessing something to do with lift and duration, but I'm at a loss here, can you help.
Tony - Memphis
>I've heard that term too. Not sure where it originated. My understanding was that in the early days, there were only a few lobe designs available. It was surprisingly difficult to develop a profile. So, it was easy to describe a lobe's size relative to stock rather than by the numbers. Plus, nobody knew what the numbers meant anyway. As time went on, it became easier to produce profiles (computers happened) and we needed a finer resolution to compare lobes, so we started advertising the lobes by specific lift and duration at a specific height (usually 0.050" for solids and 0.006" for hydraulics). Nowdays, there are all sorts of ways to compare lobes and we look at plots of the profiles on top of each other, acceleration numbers, etc. etc. Of course, I've been out of the biz for many years now, so I don't know what else they have come up with.
Tony
Phil Joines Krum,Tx
>The cams were designed to have maximum torque at specific rpm ranges. �Full Race� cams had the peak at a much higher range than the �. It made them difficult to drive on the street. Really rough idle, etc. so they made the 3/4's to sell to average Joe for his street car.
Re: And what Tommy now drives...
Larry in NW Ohio
>That is without a doubt the coolest sound next to the dragsters. Larry
at least two errors in this litany
Bill Tindall, E.TN
>Hydrogen burns with a colorless flame and its flame is relatively cool as flames go. .
The fuel mixture can't be compressed to a solid or near solid what ever a "near solid" is. If anything, the fuel might be compressed to a supercritical fluid.
The 44 amps to each spark plug statement seems suspicious. I don't know what the spark voltage is but say its 1000 volts. That is 44 thousand watts to each spark plug. Those are going to be some kind of spark plug wires! That is close to the HP of the engine.
Jason Roehl in Lafayette, IN
Re: at least two errors in this litany
>1. Hydrogen may burn with a colorless flame, but that's not the only thing going on there--the hydrogen is first being dissociated from the water molecules in the air from the heat of the exhaust. Plus, there are a number of other compounds in the exhaust gas--who knows what all else is going on post-tailpipe.
2. Compress a gas mixture enough and you get a solid. The supercharger is ramming 3000 CFM of air into the cylinders, plus the fuel (1.5 GPS). The idea behind the "near-solid" statement is that the density of what is in the cylinder when the piston is at the top of the stroke is getting pretty close to the density of a solid, which is roughly 1000 times that of a gas.
3. Spark plugs typically fire at about 20kV, give or take. Most ignition systems (even in a typical street vehicle) are capable of delivering up to about 50kV. Most cars may not reach 44 amps, as that is high-performance range, but the amperage in a plug wire at firing will still peak in the tens of amps range. You're also forgetting that is not a constant figure--it's peak, and most ignition systems only give about 20� of spark duration per cylinder. In a 4-cycle engine, that's 80� of spark per revolution (only 4 cylinders fire each revolution of the engine). The rest of the time, the capacitors in the ignition system are charging. BTW, 44A x 1000V = 44kW, which is about 58 HP, far short of the 6000 HP output of the engine, which is probably a brake HP figure anyway, already compensating for the parasitic losses of the accessories on the engine. 44A x 20,000V x 80�/360� / 746W/HP = 262HP. But it's not even that high, because the 44A and 20kV are peak numbers--once the arc is established, those numbers drop off. And, like the post said, the spark plugs are consumed halfway down the track--the heat of the cylinder walls and the heat of compression take over for igniting the air/fuel mixture--AKA, dieseling.
If you watch just a few drag races, you'll see how much damage they do. It's not uncommon to see a car blow 2-3 cylinders and still win a race. You can tell because each cylinder has an exhaust pipe, and when a cylinder blows, it's pipe will stop shooting flame and shoot a whitish smoke instead.
Those 500 C.I. engines are amazing. Consider that Ford made a 460 C.I. engine for its full-size trucks up until '97, but it was only able to put out about 250 HP. Gearheads might drop a few thousand dollars into a 460 and end up with a pretty hot 500HP engine--still just a small fraction of the 6000HP the top fuel dragsters get. But the Ford will go many, many more miles and turn far more times than the 900 or so revolutions the racers get out of their engines.
Jason
Let's see
>You're an automotive engineer with drag racing as a hobby...
Whatever, Jason, thanks for the enlightening post.
Nah....
>...just a bit of an amateur wrench turner who hangs out at a few automotive forums, where this has been discussed before with some automotive engineers chiming in.
Jason
Ok, only 2 errors and one misleading claim
Bill Tindall, E.TN
>"With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition."
If a gas or vapor is above its critical temperature it can not be compressed to even a liquid. So, for example, below 31 C carbon dioxide can be compressed to a liquid and at still lower temperature a solid. But above 31 C one can compress carbon dioxide to any practical pressure and the result is a supercritical fluid- a gas with liquid -like behavior. The critical temperature for nitrogen is -147 C. So the cylinders don't see anything other than compress gas. A meaningful metric for this claim would be what psi this vapor-gas mixture is at. I suspect that it is not particularly high exiting the supercharger.
"The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases." The first misleading point is the source of the hydrogen. The hydrogen atoms from the fuel will dwarf by many fold that from the damp air. There may be some minor dissociation of water to hydrogen atoms but it is not great. What is powering this engine is the reaction of hydrogen atoms from the nitromethane with oxygen to make water. This reaction is by far the most energetic of the various reactions possible. If this reaction was going backwards to any significant degree the engine would be cooled.
There are two sources of color in a flame. There are electronic rearrangements of the atoms in the flame that can make color- for example fireworks. And there is black body radiation. Things hot emit light. The hotter they are the shorter the wavelength of light. "White hot" refers to anything hot enough to emit white light by black body radiation. "Red Hot" is cooler. Yellow is in between. I don't know why the flame is white but it will be one or both of these sources, not burning hydrogen dissociated from atmospheric water vapor.
"Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder." The ampere is defined by a number of electrons per second. So one could get 44 amps by passing a pulse of only one electron through a wire in a very short time. To compare this to an arc welder capable of delivering bizzilions of electrons per second, hour or what ever is at best misleading. The proper metric for this claim would be peak power, or average power delivered to each plug. So, for example, my electric fence charger is sized by the power it delivers per pulse, not by the amps.
Before these claims are distributed again their original source needs to get the science right. These engines are indeed impressive enough without embellishing the claims.
Bill-who lives almost within ear shot of Bristol Dragway. Someday I will satisfy my curiosity and visit the place.
Like any summary for the masses
>...it will likely trade technical accuracy for readability.
You're right that the supercharger isn't doing much compression. Street rods will have superchargers that push an extra 6-9 PSI into the cylinder. The compression that makes the fuel/air mixture incredibly dense is the compression stroke of the piston. So, 15 PSI of atmospheric pressure, plus another 20(total guess*) from the supercharger isn't much, but when it gets compressed at a 8:1 or 10:1 ratio, we're starting to see some real pressure.
*These numbers are where my knowledge of dragsters starts to break down. I know street-rod superchargers might have a parasitic load of about 50-60 HP, maybe as high as 100 HP, but the dragsters' superchargers have a parasitic load of 800 HP. I suppose the PSI of boost could be calculated from 800 HP pushing 3000 CFM, but that's something I'd have to do a little research on--it's not a formula handy to my neurons. I don't even know for sure what compression ratio a typical dragster runs. Small engines tend to run more in the 10-11:1 range, but supercharged engines usually run less so that the supercharger can stuff that fuel/air mixture in. The OP said it's a hemi engine (hemispherical or "domed" combustion chamber), which leaves even more room above the piston at the top of it's stroke, resulting in an even lower compression ratio. But, being it's a purpose-built, short-lived machine, they may run those ratios way up to make power at the expense of reliability. I suspect they do based on what I said before about the power streetable engines make in the 500 C.I. range.
Sorry if I came off as too argumentative, that was not my intent. I do appreciate the look at it from an ideal gas law standpoint, but like I said, whoever wrote the original was probably making it sound a little better for a wider audience.
I liked the analogy of spotting a Vette 200MPH and a running start, and still blowing by them halfway down the track.
Jason
AZ, Colorado Springs
>I don't know where you guys are getting 900 total revolutions on the engine between overhauls.
During the run, the engine runs for about 2:20 (two minutes & 20 seconds). I've been to a lot of drag races and timed it many times. I've been curious about total run time, since they have no cooling system, not even water jackets to have any coolant, as they did in the "old days". (Of course, heat in the clutch is a bigger concern for the crew chiefs these days, since the cars have no transmissions and use clutch application to control the transfer of horsepower to the rear wheels and the pavement.)
The idle speed is about 2500 rpm, and the run lasts about 4 seconds.
2.25 minutes at idle gets you 5375 revolutions, and the four seconds of the run (0.067 minutes), at about 10,000 rpm, gets another 670 revolutions. Now you have at least 6045 revolutions. You must also add in the increased rpm during burnout and the time spent reversing from the burnout. I did not try to calculate the additional revolutions for the burnout, as I don't the rpm during the burnout.
Also, the engine is warmed up about 30 minutes prior to the run, for about three minutes (nearly all at idle speed, except for a couple of rev ups to seat the clutch -- and add to the show for the fans), so you can add another 7000 or so revolutions, for a total of more than 13,000 revolutions.
That's still a pittance compared to your daily driver (about 6 1/2 miles on the highway in my Chevy pickup truck) but be careful with your math!
P..S. Don't ask me anything about football or baseball.
Re-read the OP...
>It said "900 revolutions under load". That sounds like it jives with what you posted--670 revs for the run, plus a few hundred more for the burnout at most.
Impressive at the other end of the spectrum is the F1 engines--they run at about 18,000 RPM much of the time, and they only get one engine per season per car. Of course, with that reliability comes a much, much greater cost.
Jason
