Lawn mower battery (OT)
Larry in NW Ohio
>I have a used Toro mower with a battery. Of course no charger. Can someone tell me what the voltage these are? It has 6 cells, does that mean it would be 9 volts? I have several DC chargers, if it would be 9 Volts can I put on any 9 Volt charger so long as it does not put out to many amps? Thanks Larry
Re: Lawn mower battery (OT)
Ronald
>Larry you better go to Toro web site and look up manual and see just what the charger is suppose to do. that is volts and amps. just go to google and type in the model number and you should be able to find it. and if that don't work call advanced auto maybe they can find out on the battery.
Tom MacGregor
>Every riding mower battery I've seen has had six cells and has been rated at 12 volts. I charge mine with a regular 12V automotive charger. Figure a "trickle charge" overnight at 1 to 2 amps, a one hour charge at 10 amps. Remove the caps while charging and make sure it's not low on water.
Dan Donaldson
>If it is a lead acid battery, then a 6 cell battery is 12 volts.
>Larry, we don't have enough info to answer. My first thought was it was an electric mower with a battery in it similar to a rechargeable drill. A NiCad or something similar. That would be around nine volts. But if it is a gasoline powered mower with a lead acid starter battery, then it is likely to be 12 volts. In either case, the charger would have to put out one or two volts more to charge the battery. If it an electric mower, double check with Toro or somebody like Batteries Plus, if it is a lead acid battery check with Toro or Advanced Auto or somebody similar.
del schisler
>the battery is 12 volt's use a reg 12 volt charger to charge That is what most people use a care battery charger 12 volt It will not over charge That is most chargers Don't ust a boost type That will put more that 12 volt You know that when you buy a new mower the battery is warrenty for 6 mon. It should be longer but not If the battery is in need of charging All the time It is about time to get a new one and let the old one retire I charge mine for about a hour or so before i put mower away If yours set for a long time they will go down Or at least mine will Most of those battery's are as cheep as you can get as far as quality If you could modify the battery compartment and get a car battery with lot's of cranking amps It would last for a long time Just charge ever so often That would be a good fix my 2cent's worth
Larry in NW Ohio
>I`m sorry I wasn`t more clear. The mower I have is a 21" rear wheel drive Toro with battery start. That is the only thing it does is start the motor. The battery pack is only about 3" X3" X5" and has 6 cells in it each one about the size of a D cell battery. I tried to look on the web site and could not find any thing about the voltage. Thanks again. I`d appreciate any info. Larry
del schisler
>here i belive is your battery I did a google search 12 volt Look at it if it is not look at google again Their may be more than this one???
http://www.apexbattery.com/toro-walkbehind-battery-sealed-lead-acid-batteries-toro-batteries.html
Re: Lawn mower battery (OT) *LINK*
Bob Entwisle in NJ
>If the battery that Del linked to is similar to yours, it is a 12 Volt sealed lead acid battery. Here is a link to info on charging SLA batteries.
A typical 1 or 2A automotive trickle charger will probably get you going. Don't leave it on too long, as in days, as you may cook the battery. If the terminal voltage on the battery measures much below 12 volts, (2V per cell) then the battery may be a gonner.
http://www.powerstream.com/SLA.htm
Larry in NW Ohio
>Thanks everyone, I have learned enough to take care it, but if anyone has more to add please don`t be bashful. I like reading about something I`m working on. This is why I just love this site. A person can learn so much about anything. Thanks Ellis and all you people that help. Thanks again. Larry
Jim DeLaney, Austintown, Ohio
>Larry,
One of those little 'Battery Tender' chargers - about $20 for the Sears or Auto Zone versions - works great for these small batteries. They come with a harness that you can hardwire to the battery and run outside the case to allow easy hooking/unhooking it.
I have my small tractor set up for one, and just keep it on all winter so I know the tractor will start when it's time to plow snow.
You do know about 'Lake Effect' snow, I presume? ;-)
Jim D.
