Drawer Knobs
Drawer Knobs
Drawer Knobs
James BB
>I wonder if anyone can help me with a design question. I'm just finishing a wardrobe (in American Cherry) which has a single drawer at the bottom beneath the usual cupboard part for hanging clothes. I'm using turned beech knobs (ebonized and waxed) for the doors and for the drawer handles. Now the question: should the drawer handles be placed midway between the top and bottom of the drawer or slightly above midway and if so by how much? Design books mention this but I'm not sure what to do and how much difference people think it makes.
Any help or experience will be most gratefully received!
James
Re: Drawer Knobs
Re: Drawer Knobs
Lee Schierer - McKean, PA
>I don't believe there are any hard and fast rules of design for this.
I usually go on how it looks in relation to the total piece. You can easily do this with a bit of double sided tape on the back of each pull and stick it in place. If you don't like how it looks you can easily move it.
Lee
Re: Drawer Knobs
Re: Drawer Knobs
Gary Smyth
>Pick what looks best. If it is Shaker style shop drawings have them centered are centered.
Re: Drawer Knobs
what I do....
Bill Tindall, E.TN
>fasten them on temporarily with double sided tape, step back and see how they look. The answer depends on so many factors that there isn't a definitive answer.
Also, I sometimes look in books for similar items and see how I like knob placement.
Re: Drawer Knobs
it's a perception thing
Jim Pugh
>with the drawer down low, centered knobs tend to look low so some folks put them up a little. The 'stick em on with tape' idea seems like a good way to check it out. Put them on and leave them for a day or two and look at them as you go by. You'll know what you like soon enough.
Re: Drawer Knobs
It May Actually Be a PERSPECTIVE Thing *LINK*
charlie belden
>When it comes to pulls, what you SEE is a matter of perspective - and that's a function of how far off the ground your eyes are and how far you are away from what you're looking at.
In the attached photos you can see in Photo 1 that when you're standing close and looking almost straight down the pulls appear to get progressively closer as you go from top drawer to bottom drawer - the lowest drawer pull appearing to be set near the top of the bottom drawer.
Oh - the reason for the larger than necessary space above the top drawer - I'd planned on pull out - fold up - stock supports for longer parts to be mortised. Found a metal ones that didn't need all that room - after this base unit for the mortiser was finished- naturally.
Backing away a bit as in Photos 2 & 3 it still looks like the pulls aren't centered on each drawer's height.
Back up even more, and squat down a bit so you're eye level is even with half the distance between the top of the top drawer and the bottom of the bottom drawer and you see the actual, rather than the perspective distorted perceived, location of the pulls - each centered on each drawer's height.
I'm guessing that graduated drawers aren't graduated strictly for utilitatarian purposes. Sure, you've got different height stuff to put in them so you need different height drawers, but the heights are often not determined by or in the order dictated by what is to go in them.
I suspect they're graduated often in a non-arbitrary way - and likely graduated on some mathematical formula - which you will, coincidently, find in design books. Graduated drawers may be an attempt to correct for perspective distortion.
The attached link may be of interest if you're thinking about doing graduated drawers on an upcoming piece.
If you're wondering what the thing in the photos is for - what with the wheels on it and the pretty beefy frame - the answer is - a pretty heavy (182 pounds) mortise and chisel mortiser. And if you look closely you'll see that not only the drawers are graduated, but the box joints as well. I have real trouble with K.I.S.S. (Keep It Simple Stupid).
Graduated Drawers - formulas and basis
