Wow, I'd like to see this thing running... *LINK*
Corey Megal
>From way far away, behind a bullet proof shield.
Has anyone ever seen something like this? It looks like a lathe with a saw blade attached to it. Crazy.
Work safe,
Corey
Crazy Saw
Corey Megal
Work safe,
Corey
Crazy Saw
Re: Wow, I'd like to see this thing running...
Bruce, a MN Galoot
>that looks like a Shopsmith mark 1 with all the parts removed. I wouldn't stand in the same room as that bugger.
Bruce
Shopsmith 10ER
>as Bruce says, lots of parts missing. Critically missing is the table assembly, which sits on posts that mount on the base visible below the blade in the pictures. Once you wrap a table around the blade, it's not so scary looking. In addition, the spindle is fully extended in the photos, not necessary in table saw mode (the spindle gets extended mainly in drill press or horizontal boring machine mode). All of this contributes to a horror-movie effect, which will certainly improve the salability of this tool.
$75 seems a bit steep for what is, essentially, a parts source for a restoration project. The 10ER is something of a cult Shopsmith (see next paragraph). I've seen these listed for $750 in fully restored condition, although I've also seen them go for $15 in rusty condition (I know, because when that one went, it came to me; still rusty, no time, no place to put it; and why did I buy it?).
Why so high? There's a lot of cast iron, as opposed to the aluminium that the later Shopsmiths used, and pretty decent bearings. Dale Nish, who had something of a reputation with his dad in the 1970s for art turning (one of the early advocates for turning spalted wood, and famous for his VERY rough turnings, kind of the Peter Voulkos of the turning world), started out using 10ERs for his turnings because it was a cost effective way to get a big swing.
>Quote from seller: "...thankyou and have a bless day."
Anyone within 20 feet of that saw better have a ton a blessing stored up, and several extra guardian angels ready.
Happy Woodworking!
Brian in Brighton
>They had something like that in a woodworking magazine that had an article on Mexican craftsmen making dolphins and whatnot out of ironwood for tourists. They used the saw blade to "carve" the wood. Looked scary as can be. I guess it's good we have OSHA to keep companies like that from being here in the states.
Brian in Brighton
Even with OSHA...(rambles a bit)
>In 1976, I briefly worked as the maintenance mechanic in a waterbed frame factory. They would take delivery of truckloads of 2x10 No. 2 pine to make the frames, 20 feet long or so. The larger of their two forklifts still wasn't big enough to take 1/2 of a flatbed of wood off and into the factory - it tended to tilt forward onto its nose, a problem management solved by having every available worker run over and jump up on the back of the fork to add counterbalancing weight. Sometimes, I (and others) would have half of one foot on some flat surface of the forklift body, while holding on with one or, if lucky, two hand(s) to the operator's cage.
That was the most dramatic of their multiple safety failings. I regret, looking back, that I didn't call them in to OSHA after my two months there; but I had a new baby and a VERY rambunctious four-year-old, and a full-time night job (here's how well they paid: my salary improved when I took a job as a school custodian).
James Runchey
>I have one just like it, only complete. I bought it used in 1959 for 100$ and still use it almost daily in the drill press mode. It makes into a decent lathe, also a 12" disc sander, very handy. I used the saw mode for several years till I got a decent saw. It was a very well-made, heavy duty machine, weighs a ton. Looks like most of that unit is missing, like the table for one thing. Best money I ever spent.
Ax-handle lathe, circa 1880
Bill Hylton
>About 15 years ago, I visited a furniture-maker in Montgomery County (PA) to talk about using some of his stuff in a book. He was making a line of bar stools that used ax handles as legs. The company from which he was buying the handles had upgraded its equipment a few years before, and he bought the lathe they'd been using since the late 19th century.
He was pretty blase about it, but I had that "boy, does that look scary!!" reaction. Did not see it running. Much larger than the one in the original post, and using multiple blades (like dado heads).
Bill
