Children's play fort
jp in 'rural' Festus
>Been away for some time now and I've just now had a chance to try to get caught up on the comings and goings at WC. Hope I didn't miss much ;)
I went to look at children's play forts the other day at the local big boxes and returned rather shell-shocked. A $1000 for that?! I suspect you have already figured out where this is heading, but does anyone have any online/print resources that you could direct me to? Knowing the folks here, I'm sure several have already built one. If so, would you mind sharing your expereinces? One issue that I'll have to iron out is the site. We live on a hill, so there is very little flat ground. I'd prefer to not spend my time building a retaining wall if I don't have to, as I like to spend money above ground. So how flat does the area need to be? Should I pour footings? The list of questions goes on and on.
I'm starting out on this to save a few bucks, but if it turns out like most projects, I'll wind up saying, "Yeah I paid that much for it."
Thanks,
JP
Re: Children's play fort
Joseph Mulherin, Sr
>Suggestion: Google "children's play fort plans" for a menu of places which have the plans and kits.
Joanne in Point Pleasant, PA
>My friend and I built this freakin' cool fort for her grandson. She found the plan on Buildeazy.com, I think. We modified it. The plan called for plank roofing. I thought it would be fun to �paint the sky�. Three walls are 2/3 height walls. The 4th is a climbing wall with a hinged door. There is also a cool trap door in the floor. You climb up the ladder underneath and go through the trap door. The plan also called for putting a tire swing on the climbing wall side, but we thought that looked dangerous. Her grandson is only 6. She already had �Old Radial� on a tree, so we moved him to the fort. If you had more kids, you might want some swings. We did not. I�d like to add a �Captain�s wheel� inside and maybe a spyglass. One of the things we liked about this plan is that we did NOT have to dig and put in cement. The thing is very solid! Our band had a rehearsal at that house and of course all 4 of us had to climb up and sit inside for a while. Plenty of room. Not quite fine furniture, but this was a fun project. I think she spent between $500 and $600 for materials, including the slide (which is about $80--you might be able to find it cheaper). The big rigs like that that Lowe's and HD sell are closer to $2,000 installed. If you build one yourself, make sure you get some help. That pressure-treated stuff is heavy! For some parts (walls, floor, roof), we opted for plain pine or cdx plywood and painted it all with a deck sealer or outdoor paint.
Fort
Fort
Fort
Thanks for looking.
