Adhering Paneling to masonry wall
Ben Ragusa, S. Jersey
>Good Morning.
As part of a project to construct built-in mudroom cabinets, I need to attach bead board paneling to a brick wall which has a smooth plaster surface. There is no wood to nail or screw into. Having no experience with construction adhesive, I am seeking your advice. The construction adhesive label says it needs to cure for 24 hours, so I am trying to come up with way to hold the panels in place while the adhesive dries. I have two ideas- one is to cut strips off a 2x4 and flex them accross the room (it's only about 6 feet wide). The other idea is to temporarily use tapcon screws to hold cauls to the wall, then remove the screws and fill any holes not covered by moldings. What would you recommend? Any other ideas?
