OT: Electrical switch source
Jason Roehl in Lafayette, IN
>I'm looking for a 120VAC light switch that has some sort of indicator light on it when the switched circuit is powered on, and no light when off. I've found plenty of the type that have an always-on light for easy location in the dark, but I have a light switch in the house that controls a light in the garage. I'd like to have a better reminder that it's on--an attention grabber, as it were. Actually, I have several places I'd like to stick one, including at least one at our church.
Thanks in advance,
Jason
Re: OT: Electrical switch source
Re: OT: Electrical switch source *LINK*
Curly Smith
>You can probably find them at the Big Boxes as well
LEVITON SINGLE POLE SWITCH WITH PILOT LIGHT
Thanks, but...
>...I'm guessing "pilot light" means the indicator light is always on, something I've found plenty of, and not what I want. I want one that lights up when I turn the switch on, and is unlit when the switch is off.
Jason
Try this *LINK*
Bob Entwisle in NJ
>Try this Leviton Part number 1201-PLR.
I think it is what you are looking for.
Grainger has em, but not cheep, shop around.
http://www.grainger.com/Grainger/items/5C325
Bingo!
>I don't want them for $20, but I was able to do a quick Google search and find them for half that. Now we're getting somewhere. Thanks!
Jason
Re: Thanks, but...
John McGaw
>I wouldn't jump to that conclusion. Most of the Leviton switches which feature a "pilot light" are described as the light being on when the switch is on. You should know that to be wired properly this type of switch requires a neutral. Someone doing a hack wiring job might try to use a ground instead of neutral but, even though this would work, it wouldn't be proper.
Look up the Leviton 5628 to see the sort of switch I'm describing. I've found it for sale for around $8 but if Decora isn't your thing they make standard switches with the same feature. A search a Leviton's website turns up quite a number with the search term "pilot light"
And....
Dan Donaldson
>A switch box does not necessarily have a neutral.
Jim Pugh
>There are switches like you want because I have several. Mine are duplex type switches with the switch in the top position and the light in the bottom position. On mine the light is quite large. As I recall, you just wire it in like a normal switch.
Re: And....
>I've got that part covered, Dan. I've done my share of wiring, as an amateur, with more to do when I get a round tuit (the kids' rooms both will get ceiling fans/lights, and the garage needs a more comprehensive lighting setup).
I haven't pulled the plate on that particular box recently, but it's a double-gang box, and I think there's a neutral available in there.
Jason
