DeWalt 735 Planer Problem
Tony - Memphis
>I've been using this thing for a couple of years and been real happy with it. Recently, I noticed scratches in the wood. Not bumps, but scratches. New knives didn't help. I read somewhere else that someone had a similar issue and it was teh screws that hold the knives in hitting the wood. Anybody else experienced this? The groves are not very deep, but have become quite a nuisance. I have to do quite a bit of handwork to get rid of them. I've cleaned, checked, re-aligned, etc. and they are still there. I'll check the screws tonight. If that's the case, DeWalt sent the owner new screws, so maybe I can get them to send me some. Might could gently file the offending screw heads. I will switch some screws around too and see if that helps. I didn't think the screw heads were anywhere close to the wood surface, but I guess they are. I even got some snipe the other night, which I have never had with this planer.
Thanks,
Tony
Re: DeWalt 735 Planer Problem
>I assume this is on the top side. If the scratches are on the bottom side it could be grit on the platten. I'll have to look at mine and see where the screws are. I don't remember them being even close to the edge of the blade arc.
Bart Goldberg
Bart Goldberg
>Tony, I have the same planer. Please do post the solution to your issue so we can use this as reference for the future.
Regards
Bart
>Tony It could easily be the screws that hold the blade. I just did a rather crude measurement with a feeler gauge and there is only about .040" more or less between the arc the blade travels and the arc the screws travel. I would think they would have to be pretty loose to make marks. If your blades were very worn or sharpened instead of replaced they could be short enough to cause the screws to rub. I would check to see if they are all tightened and that there isn't any grit under them.
Dick Coers
>I have only used one of these at the local Woodcraft, so I opened an online manual. That confirmed that they have a pressure bar, stated as contact plate in the manual. Could you have damaged that plate somehow? Maybe that is scratching the wood. It seems to me that if the screws were contacting the wood, they would leave some discoloration or slight burn on the wood. You would at least be seeing some heat or plating wear on the screw heads if they were hitting the board at that rpm. Raise the head as much as possible, and see if you can feel some roughness on the contact plate.
forgot to add............
Dick Coers
>One more thing, maybe a damaged pressure bar is causing the snipe as well. Pressure bars are supposed to press the wood to the bed, limiting wood movement and snipe.
>Upon occasion, some chips of harder wood can get stuck near the blade holders. They also seem to be partially "embedded" in the rollers. I've had this problem upon occasion. I usually vacuum out my DW 735 and clean the rollers when I have the problem.
Raise your DW 735 up a few inches. Look inside with a reasonably bright light. See what you can see. If the rollers are dirty and have chips, it is easy to spot. The blade holder is more problematic due to its location.
Larry in NW Ohio
>Tony one way you might be able to find where it is coming from is to run a board in and then shut off the machine when the board is through. Then unplug the machine and take the top off and look around the board to see if you can see where it`s coming from. Good Luck Larry
Tony - Memphis
>Thanks for the tips. I tried most of them already. I took a long look last night. Nothing obvious. I did notice the screws had some raised metal around the hex. I tried marking the screw heads with a Sharpie to see if I could see where the marker got rubbed off, but that didn't get me anywhere. I marked where the board was scratched and it did seem to line up with a screw head. I filed the raised ridges from a couple of screws in that area on all three knives and that seemed to help. It was getting late and I had to stop fooling with it. I measured the width of the scratches and they did seem to fit the width of the socket in the screw head. So, that could be the issue. I'm very careful when I change my knives and they are all clean and tight. My rollers are clean. I completely felt up this machine and didn't find anything near the wood path that would scratch it. Next thing I might try is to move the screws around and see if the scratch moves. Just looking, its hard to see that the screw heads come anytwhere close to the wood, but its hard to see for sure. I may put a piece of tape on a couple and see if it gets rubbed off. Or maybe some rubber cement. Thanks again for the help.
In spite of this new issue, I'm still pretty happy with this machine. I'm building a tiger maple tea table and the boards come out of the planer glass smooth (other than these scratches and a few tiny raised areas from the blacde nicks - even brand new blades have nicks or get them rather quickly. I'd love to get one of the insert heads, but I don't have the budget at the moment.
Tony
Oh, I think the snipe may have been because my boards weren't flat to start with. So that might be my own fault. I'll check into that.
Careful with those screws
Jesse Cloud
>When you are tightening the screws, don't put too much torque on them, they break pretty easily - don't ask me how I know this ;^)
>I have the older 733 model that has the sharpenable knives. These knives are much heavier and bolt in. You use a a pair of gage "blocks" to set the knives. Once I managed to set one of the knives wrong. Got the posistion way off. Do you need a similar device to set your knives? If so, I would suggest checking the setting to see if you got them "out" as far as they should be.
Maybe your knives are not set right
Grant in Iowa
>Double check your knife setting depth. Sometimes the included knife setting jig isn't positioned right, causing your symptoms.
FWIW,
Grant in Iowa
