Delta 50-760 dust collector wiring
Chuck in ND
>Has anyone here wired one of these up for 220V ? The schematic inside the motor electrical box isn't telling me much. The wires inside the box are numbered, except for the 2 incomeing supplies and the ground.
Re: Delta 50-760 dust collector wiring
Re: Delta 50-760 dust collector wiring *LINK*
GalenV in Iowa
>I hope the copied link works for the Delta site. They give instructions how to change the voltage. Looks like there is a jumper (plug in) that is just switch. They do say you need to change out the power switch for 230 as well. Looks like you need to order the switch and new wire with plug unless you can find a local sub.
Pick the link to the motor as it shows the setup.
Galen
http://support.dewalt.com/cgi-bin/dewalt.cfg/php/enduser/popup_adp.php?p_faqid=3127&p_created=1172681005&p_sid=klowoFCj&p_lva=4826&p_li=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjcsMjcmcF9wcm9kcz0xMzE0LDEzMTYmcF9jYXRz
Chuck in ND
>Hi Galen. Nothing in that schematic looks familiar with what I have. The problem I'm haveing is the schematic inside the motor cover shows 4 wires numbered 1 through 4, one for each terminal of the new 220v switch. Inside the electrical box of the motor that I have, there are 4 wires that are numbered 1 through 4. Whats throwing me off is that the incomeing power wires are not any of the wires that are numbered. Seems rather odd to me. I would think that the two power wires would go to the switch.
Larry in NW Ohio
>Can you post a pic of the drawing from the motor. Larry
Chuck in ND
>Hi Larry, here is a picture of the schematic.
Chris Friesen
>I just went and took a look at mine. Currently you have wires labeled 1 and 3 marretted together with a wire that goes to one side of the switch, and you have wires labeled 2 and 4 marretted together with a wire going to the other side of the switch. There should be a spare marrette inside the switch cover.
1) Undo all the marrettes.
2) Marrette together wires 2 and 3.
3) Marrette together wire 1 with one of the wires going to the switch.
4) Marrette together wire 4 with one of the wires going to the switch.
Done!
Re: Yes
Brian in Brighton
>I did mine and kept tripping the breaker until I looked at it much more carefully. He is right, and don't forget to change the plug.
brian in brighton
Re: Delta 50-760 dust collector wiring DONE DEAL
Chuck in ND
>Thanks for your help folks. I decided to just let an electrician do it. I didn't feel comfortable enough with it.
