OT chngng Honda Accord low beam
Frank in Forest Hill
>Gentlemen,
Help settle an argument between me and my son.
We both have 2005 Accords. When changing the low beam I jack the vehicle , remove the wheel and pull the fender plastic inner liner back to access the lamp.
When he changes a lamp On the battery side he loosens the battery hold down and shoves it to the side and works from the top of the vehicle and I GUESS must bend in half to make the chg.
Has anyone reviewed the process in the repair manual or used the on line repair information to determine the "better way" ?
Thanks, Frank in Forest Hill
Re: OT chngng Honda Accord low beam
Mark Nowicki
>Based on my experience with a 2002 Accord your son is doing as described in my owner's manual.
I cannot imagine an engineer designing it to be changed by your method, (unless they work for Renault, DAMHIKT)
Mark
Whatever works
>It sounds like the factory solution assumes enough agility to reach the bulb from the top. Seems like, if both solutions work, they're both the right solution.
Remove the bumper first
GolfSteve in Calgary
>On my Volkswagen Golf in the manual under "changing the light bulb" it says "Take to nearest VW dealer for service".
I found the easiest way to change a bulb on the Golf, especially on the driver's side, unbelievable as it is, was to 1) remove the bumper, 2) remove the headlight, change the bulk, then reverse.
Unless you have two-dimensional hands it is impossible to change a headlight on that car without either removing the battery (which resets all the electronics) or the bumper.
I'm an engineer and even I think this is stupid.
I just sold the Golf (hooray) and bought a new Jetta Stationwagon. The new lights are extremly easy to change so the engineers must have agreed that the old way was stupid.
GalenV in Iowa
>What ever happened to the good old days when you could replace a sealed beam lamp with a Phillips screw driver right from the front of the car? Now it is stand on you head or jack up the car and reach up and twist the plug to remove the bulb. BUT WHATEVER YOU DO, DO NOT TOUCH THE BULB when you replace it or you start all over when you light it up and it burns out. Now you sterilize your hands with alcohol wipes when you perform the surgery.
Yes, I need to walk into the light and be at peace.
Galen
VW engineers
>Back in my youth, VW had a long tradition of making parts either elbows-out accessible or insanely inaccessible. The capper was the Type 4, in which you had to be a magician to remove some of the spark plugs. Thank goodness, they were so ugly very few sold.
The Type 4 engine was used in the Porsche 914 (in which, by the way, it worked much better, even though the engine access was only about 10 inches wide, by the width of the car). I was working briefly as a VW mechanic when they first hit the market, and we grease monkeys had quite a few chuckles when one of us overheard a salesman tell a potential customer that the Type 4 "has a Porsche engine."
Re: Remove the bumper first
John in Calgary
>Ah, spoken like a true VW owner, you definitely have the passion - all the dumb things that would drive you nuts in your old car, but you bought another one.
So, I guess this means you aren't GolfSteve anymore. Which wagon did you pick up, the TDI or one of the gassers? I plan to replace our Passat wagon with one of the TDI Jetta wagons one day (and I too have the passion, so many little things about VW ownership that drive me crazy, but I wouldn't own anything else).
John
Victor Parisian
>First remove the bumper, then slide a standard sized tire up under the engine, then remove the four bolts that hold the sheet metal, disconect electrical wires and throttle wire...
Ooops, I immediately thought of dropping the engine in my 67 VW van when I first saw your post. Sounds easier than changing the stupid light.
Victor in Houston
My sweetie and I had R&R on a VW van motor
>down to 30 minutes, tops.
Lucky did it on lunch hour
>One of my best employees ever, Jeff Hoffa (a.k.a. "Lucky"), was a VW nut. We had VW carcasses all over the place while Jeff worked for me in the '80s. I remember one time he did a ring job on a Beetle over lunch hour. I was astounded, but not surprised. Jeff brought this same breed of creativity to our projects.
This all brings up the notion of mechanical ability. Whether it's natural or not, it is a trait that some are born with and some aren't. We do the best we can with what we have.
>Yes, I should now be called Jetta Sportwagen TDI Steve. The diesel engine has me hooked. My last golf was a TDI. Loved the engine but the rest of the car was so/so.
When test driving cars, every other model in the same price range was either noisy or tinny, and only the VW had the diesel engine, so I chose to stay with VW despite their flaws. VW's biggest flaw is their service department, which I avoid like the plague.
VW's also have a very nice interior. I think the diesel engine makes the biggest difference in ride quality compared to a lot of other cars...the engine is quiet, it's powerful throughout the rpm range, it doesn't smell or smoke, but it is expensive to repair. Gasoline engines in mid-size cars feel anemic in comparison and you have to rev them so high to get into the power band that they're noisy.
Bugman
Tony - Memphis
>The title of oyur post made me look! I was really into VW's when I was in high school. My friends called me Bugman. I still run into people now and then that don't know my name, but remember Bugman. I wasn't as good as your employee, but I managed to keep mine alive and was always tinkering with it. Finally had to get rid of it. It has been replaced with woodworking and a 54 Chevy, oh, and a wife.
Anybody remember the book by Muir, "How to Keep Your Volkswagen Running for the Complete Idiot?" Great book and even better illustrations. My copy is covered in '69 VW grease.
Tony
Re: Mechanical ability
GalenV in Iowa
>You said:
"This all brings up the notion of mechanical ability. Whether it's natural or not, it is a trait that some are born with and some aren't. We do the best we can with what we have."
I had to laugh as you made me think about my younger brother. He took apart about everything he owned at some time or other but NEVER could put anything back together. Did not matter if he had parts drawings or not cars, appliances and guns could be found in pieces.
He must have had some mechanical ability to take things apart or is that just being destructive?
Galen
John in Calgary
>Nah, you should stick with GolfSteve, otherwise you'd have to do the Prince thing (...formerly known as GolfSteve).
I hear you on the service - I had a period with good service at Northland after we bought our 2000 Passat (used in 2003), but then it declined into the same, more normal, schizophrenic service experience I had at South Centre with our 1994 Jetta. Now I fix things myself unless I really have to take it in (usually due to time constraints, the bigger jobs don't frighten me, just the loss of time and vehicle).
John
Alex Grigoriev
>Yep. Halogen bulbs are made of quartz, and get very hot. If the surface gets contaminated with sweat (sodium) and grease, quartz melts down.
VW not alone
>I recollect GM had a car on which, to replace the rear spark plugs, you had to loosen the motor mounts and jack the motor up. This was back when the replacement cycle was frequent enough that it was an issue.
not just GM
Bruce, a MN Galoot
>IIRC the Ford Aerovan was the same way. There wasn't enough clearance under that teeny cowling to get at the plugs, so the engine had to be moved.
Bruce, whose cousin had one and wasn't happy.
Re: VW not alone
mark nowicki
>It was a Chevy Monza with a V8 engine and air conditioning, and it was "only" one spark plug. (Chevy Monza was supposed to be a compact car.)
I used to own a Renault Fuego. The catalytic converter was in the engine compartment, blocking everything. Every repair procedure started with " remove exhaust manifold and catalytic converter".
It was a very economical car, half a tank of gas from Montreal to Toronto, and only caught fire twice.
After the birth of the second kid it was time to change the Celica GT for a minivan. First choice was the Toyota Previa, Gave up the idea when I found out that every repair required engine removal.
Mark
Re: VW not alone
Howard Norman
>I recall that on my '63 Olds one of the rear spark plugs was next to impossible to replace. I don't recall what you had to do now - just that it was nigh impossible to get to one of them. Remember that I took it to the dealer one time to have them replaced and they did not replace that sparkplug.
Toyota Prius headlight bulb $400.00 ea.
Edie Pacheco: Antioch, Ca.
>One burned out on my nephew's car and he took to the shop for regular check up. Told them to replace both. Good practice, right? They told him $400.00. He told them, "no, the car is under warranty and I'll pay for the bulbs." They told him "one bulb is free the other is $400.00."
He only got the one bulb replaced. That's like 10 or more tank fulls of gas for that car?
>Try "Tunedub". They're an independent mechanic who I've use for some major maintenance (Timing belt, turbo replacement) with pretty reasonable results. He has good prices for oil changes, etc. Tunedub is located off McLeod Trail around 39th St.
My second choice is Fifth Ave. Autohaus.
Re: VW not alone
Alex Grigoriev
>"only caught fire twice". What do you think "fuego" means?
Oh yes, on the book - showing my age
>although the son of a younger than me coworker used it (as did my younger son during his brief infatuation with VW buses).
Puts a whole new spin on "green" :^))
mdclor
Re: My sweetie and I had R&R on a VW van motor
Victor Parisian
>Yabutt...could you do it in a parking lot alone on a Saturday morning before the machine shop closed? Wife was working at the A&P as a checker on Saturday. And we needed to run to Ann Arbor on Sunday.
Victor - still cleaning grease from under the fingernails...
