OT Snow blower!!
OT Snow blower!!
OT Snow blower!!
Sawman
>I know it is only July but>>
I am in need of a new snow blower and saw one for sale. It is a Troy Built. Any one have any opions??
Let me know as I may want to jump on this one.
I think I feel a chill in the air!!!!!!!!!
Re: OT Snow blower!!
Jim Pugh, Elyria, OH
>Troy Built and some other old name lines were bought a few years ago by MTD.....which to my mind produces a lower quality product. So, you aren't getting the original Troybuilt quality any more. Just a thought.
Frank in Forest Hill
>Heavy snow or the average stuff we get in Md. I have a single stage Troy Built and it is OK here in Md. When it gets wet it is a little tough pitching it off the driveway.
Never a New Troy Built
Dustmaker Mike
>I have a Craftsman and it works like a champ. It is an eight horse 27inch dual stage. It is 5 years old and runs like a champ. I put a cheap tractor light on the front so I can clear the drive way at night.
The reason for not buying a Troy Built is I lived in Troy NY the original home. We had a Troy built tiller that we could not kill if we tried. When I finally bought a house and had a large yard to take care of I went out and bought a Troy built mower after it had motor problems and then the deck support broke I returned it. I tried a string trimmer a year later from Troy built and I could not get it to keep running. I replaced the mower with a Craftsman and kept the old string trimmer (echo) I already had the reason I was going to replace it was, it had a leak in the gas tank and is fourteen years old. I have since replaced the mower with a JD and still have the Echo string trimmer.
Any way my two bits.
David
>Many of the folks around here, myself included, buy Ahrens. I had always bought Toros for everything but when I moved from Ohio to central NY, the snow load proved too much and killed a 5hp 18" unit (snow and a very long driveway that is). I'm quite happy with my Ahrens 1128 (11 hp, 28") that blows through everything. I've had it for 9 years and it's still going strong with a factory headlight to boot :)
Grant in Iowa
>One thing to look at is the gearbox between the front augers. This is just about the most common part that fails. If you have a choice between two units, choose the one with the most robust gearbox.
Most repair guys will swear by the ones withe cast iron gearboxes, and shy from the ones with the die cast metal ones. Down side is they don't make many units with Cast Iron gearboxes any more...
Anyway, expect that to be the first part to fail, so if you have to, at least chose a maker that offers repair parts for a reasonable price.
FWIW,
Grant in Iowa<---needs to fix his snowblower with a die cast gearcase before winter...
Lee Schierer - McKean, PA
>I had a Toro for 20 years. I thought it was a good machine until I bought my Simplicity when the Toro died 3 years ago. Wow, now that is a machine. The Simplicity runs better, throws farther and doesn't clog as often. I now have to be careful not to throw snow up onto the house roof. I've blown 18" of PA snow (heavy and wet) at a slow walk for the length of my drive (200 feet) and never once had to stop or blow the same snow twice. The Simplicty will throw that much snow at least 30 feet to the side.
Lee
Figure out how much power you need...
Joe Pack
>...then buy more! I have never heard someone commplain about a snowblower having too much power, but always about having one that is underpowered (starting with me). Blowing powder snow is for advertising purposes, and a 3 hp cheapy will do that. Blowing real snow...the wet, heavy kind that really does cause you to need a snowblower...is another. If a 5 hp will do the job, buy an 8. If an 8 will do the job, buy an 11...
Better yet, try to find a copy of Tim's Binford Tool Time Snowblower DIY Retrofitting Manual and build one that REALLY blows the stuff away. Or maybe catch the Red Green show for other ideas.
