Re: Water Poly Questions?
Jason Roehl in Lafayette, IN
>I've used several different brands of WB poly. To me, there is only one worth using for interior trim--Sherwin-Williams' Wood Classics. It approaches the thickness of a cheap acrylic paint, whereas all the other brands I've used are like water. No way two coats of the others would be enough, 4 is more of a minimum. Even with the wood classics, 2 coats on bare wood is pushing it. I usually put two coats of the WB poly over a coat of Zinsser SealCoat shellac, except for high-handling items like doors, which would get 3. Of course, I'm usually spraying...
As for brushes, nylon/polyester brushes work well. WB finishes mess up natural bristle brushes. I usually use at least a 3" sash brush if I happen to have to brush out some trim. With a larger brush, I can work more quickly--put it on, spread it, tip it off and leave it alone. With quick-drying finishes, you don't want to work them any more than necessary.
Jason
