question on extension table latch
Bill Tindall, E.TN
>I ordered this latch mechanism which is for holding extension table together. I presumed it would be a cam mechanism that would tension the table together. It is not.
Is this the best hardware for holding an extension table together? What is preferred?
Re: question on extension table latch
Lee Grindinger
The truth?
Lee Grindinger
>When needed I used sash locks, they supplied the tension needed to really suck the halves together.
I'd like to see the backside end of the right hand pin of the bail you posted, perhaps I could help you with that.
Lee
Larry in NW Ohio
>Bill I have a few window latches from when we changed designs a lot of years ago at the window plant I went to every day. If you would like to try them, I could send a couple and you could try them and see how they work. I put them on all the tables we bought through the years and I really like them. Larry
Re: question on extension table latch *LINK*
>Some of those - at least the older ones - are subtle cam mechanisms, the circular ring not being really circular. Modern manufacturers may have lost the idea, though.
I agree with Lee that sash locks should do the job. There are also sash lock type devices designed for tables. The link below has one example, which is ugly and not very historical looking, but would probably do the job. While you're there, look at the "table fork," which appears to me to work like a clamping dog, with the tines of the fork getting closer together as they approach the handle. One disadvantage of this latter design is that you have a loose part for the grandchildren to turn into a toy and lose in the snow or rain (depending on climate) at the winter holiday gathering.
What I can recommend against is a hook and eye. My father did that on my grandmother's table, which we inherited, and it hurts my fingers to get that hook back into the eye.
http://www.constantines.com/browseproducts/Aligning-Table-Lock.html
Re: The truth?
Fred Davis
>Sashlocks are very handy and many appilcations besides window sash securing.
I have a small finish bench I carried to and from interior trim job sites and the drawer is locked with a sash lock.
FredD
