Shipping/Picking up large equipment - ideas?
Stephen Kirk in Quakertown PA
>I'm looking to pick up a jointer fairly soon (eying up the Grizzly G0490X, actually). I'm about a 2 1/2 trip from Grizzly with a light pick up truck. I know Grizzly often ships for free but I'll probably have trouble lining up a couple of helpers when the machine is delivered. I can probably get the machine in our truck but the jointer bed is longer than the truck bed. On the plus side, if I pick it up I get to spend time in the store and check out the equipment first.
Anyone else have recommendations on how they got big/heavy equipment from the store to their shop? I worry that if I have it delivered they'll just do "curb side" and requesting a lift gate starts adding even more cost.
Thanks!
Re: Shipping/Picking up large equipment - ideas?
Thomas S Stockton
>I usually rent a u-haul trailer. The utility trailers have a pretty low deck height and if you chock the wheels and unhitch it carefully you can slide the tool onto the ground. If you have a couple of furniture dollies you can easily get it onto them from the trailer.
I loaded and unloaded my Griggio 12" jointer easily with three people this way, nobody was straining. Just remember that it is easier to use things like comealongs, dollies and gravity then it is to use brute force.
Other option is have it delivered to the local loading dock and rent an engine hoist and sling to get it out of your truck.
I personally would drive to Grizzly and pick it up if I were that close and then unload when it was easiest
Tom
>I borrowed a friend's 4x8 tilt trailer to get my Stubby from the Roadway dock. 2 Dock boys were nice and put the pallet right in the trailer for me. I was nice and dropped $10 on each of them.
Backed the trailer into the garage, hit the tilt so the skid slid to the tail and carefully pulled the trailer out from under it. 1 man, no sweat.
Of course it took 5 guys to get the thing into the basement in pieces.
>I've got a large pick up truck. When I picked up my jointer (and a friends drill press, band saw, etc.), it fit in the back.
It was in two boxes - the bed box and the stand box. It really wasn't too much trouble for two people to slide them off the truck and put them into the garage. It did take three people to get them around the house and into the daylight basement - I didn't want to take any chances. I also have a heavy duty dolly.
If you can rent the small 4 x 8 open bed trailer from a rental place, it should work nicely. Rent a dolly if you don't have a sturdy one.
Tim in SE Michigan
>You might be suprised on the cost for lift gate. I called grizzly last week to inquire on 17" band saw with free shipping. The lift gate cost was only $32 i believe shipping weight was 414 lbs.
Fred Davis
>Any Stationary machinery I ever bought was delivered inside , where I wanted it, and set up , plugged in and test run by the dealer.
A good dealer who wants repeat business from you will do this as a matter of course and you avoid DOA equipment and you know it is set up ,runs right and if they drop it and break it , they replace it, not you.
FredD
steve mackay
>Every time I've moved the chopper around I rented the bigger U-haul. I KNOW it'll fit (its longer than bed with tail gate down), I won't break MY truck, I KNOW I won't worry about it running there & back, no worry about where it gets dropped, I can drop it move it at my leaser. PLUS . . . you just never know . . . there might be something else that follows you home from Griz and you'll be glad you had the extra room !
You can also rent
Joanne in Point Pleasant, PA
>a powerjack (sort of a mini forklift) to help get it maneuvered from truck to shop. I don't think they are too expensive.
Bob Entwisle in NJ
>Make the trip, you got Griz on one side and Cabella's on the other, you might need a bigger truck for all the stuff that will want to follow you home.
I drove out to Griz for my bandsaw a few years ago, I wanted to get a hands on look at it before I bought it. Only problem was trying to get out of there without a dozen other machines:)
I've had other machines delivered to the house, with lift gate trucks, as I recall the delivery cost didn't seem too bad for any of them, and all the drivers were helpful in getting the pallet up close to the garage/shop doors. I managed to lever and block the machines off the pallets and onto mobile bases without too much trouble, just need to think it out and be careful, a hydralic floor jack and other lifting levering implements are helpful.
Lots of good thoughts. Thanks!
Stephen Kirk in Quakertown, PA
>I'll probably call Griz and check on their boxed sizes. If we can fit the jointer bed in the truck then we're good to go. Otherwise, I might just rent a little trailer for a weekend - shouldn't be too expensive. I would like to see the machines before I buy one, I might see something different that I like. And if I'm going to drive out there, may as well bring it back with me, eh! I also like the idea of working on my own time.
I have a furniture dolly handy. No floor jack but a decent rolling car jack. Other types of low wheeled wagons are always around too.
The trick is to also not come home with a bandsaw too. But, I'm eyeing up that Rikon 14" Deluxe right now, so ...
