ADVERTISE HERE - FREE TRIAL
Drum sander opinions needed
Terry in Edmonton
>I am about to buy a drum sander. I am looking at either the Delta or Performax. What do you like/dislike about them? I am leaning towards the Delta because of the wider drum. The price is the same where I live so that isn't a consideration. Any and all comments welcome.
Re: Drum sander opinions needed
>Like my P'max 22-44 pro. Especially nice for highly figured wood. Can't speak to the Deltas.
mckay
>I have voiced this before, but I do NOT like my 22-44 oscillating sander. I am used to using a Timesaver and a new PW wide belt. Maybe I am expecting too much, but the 22-44 leaves a snipe mark and that along with machining marks is what I want eliminated. I do not know about the Delta, but I suspect that it would be the same.
>I have a Max 16/32 I bought used. It's and actual Pmax, before they sold out to Jet. I like it well enough. It is very slow and under powered compared to a belt machine (TimeSaver???) a friend of mine has, but I knew that when I bought it. I paid $400 for it. Heck of a deal compared to whatever the bigger machines sell for. ($10 or 12K?)
When mine is adjusted as it should be, it does not leave snipe. So, it is slow and a little anemic, but does exactly what I expected and wanted. I don't have the room or money for the bigger machine. I would buy it again.
I know nothing about the Delta machine, can't comment. My other tools are Delta and I am happy with them.
Robert R. Clough - Thorncraft
>Well, I have a 16/32 Performax which has worked well for me. The only reason I purchased Performax instead of Delta was space. It seemed to fit in better. If set up and used carefully a large drum sander can do a lot of work well. It can even take the place of a planer if time is no problem.
Bob Schaefer
>I bought the Delta because of the wider drum. I have been very happy with it. However, everyone is correct, these inexpensive machines are not designed to hog off a lot of material so they do not compare with the Timesaver machines. You must carefully adjust them to use the full width and then use light cuts to prevent the the telltale ridge in the center. I don't have any experience with the Performax unit but I would suspect the actual sanding performance is similar to the the Delta so I went with the one that could sand a wider piece. However, I have seldom used the greater width capacity :)
The machines are a tremendous time saver if you plane everything close to the finish dimension and then use them to level everything out and get a close to final surface on your project. You still need to do the final sanding by hand or RAS in my opinion.
Once you have one, you will find many uses for it.
andrew nistock
>I have used a performax 16-32 and even though it did a good job it was very slow. When I needed to upgrade I looked into a woodmaster drum sander. There is no comparison. Woodmaster wins by a longshot. It came fully assembled except that the switch needed to be mounted on the side of the cabinet. The company always seems to be running specials on their tools. Just watch out for shipping costs. One main advantage is that the drum speed is much slower and there is less chance of burning the wood. Very happy with the machine and for me an added plus is that it is made in the USA. Just my two cents worth. Andy
Larry in NW Ohio
>I`ll second the woodmaster, by all means. I`ve had mine around 7years and it does a great job and no problems. To get one, look into their rebuilts if you can one and try for free shipping. If your any place close to Kansas City go there. They have and Office and plant, they`lleven take you thru the plant, and you may make a better deal. But they are a very good machine and easy to work on when needed. The first thing I did when I got it home was I took it apart, not completely but just about, just to see how well it was made, I found out , very well. Good Luck. Larry
Dave Paine
>I have Performax 16/32. This was the model with the 2in dust collection size. I cut this out and replaced with 4in, like the present model. Now I have zero issues with dust removal.
I looked at the Performax and Delta, and went with the Performax since the head moves. I wanted to be able to fix infeed and/or outfeed tables. Works for me.
A BIG improvement of any drum sander will be the sanding material. I was getting a lot of burning, even with Klingspor brand regular media (rust brown coloour) and slow feed. I switched to Klingspor Al Zirconia (the blue stuff) and it has made a HUGE difference. Rarely get burning. Wood and drum run much cooler, drum easier to clean afterwards. Worth the price of the more expensive media.
