Grinder as motor
Grinder as motor
Grinder as motor
David
>This is potentially a stupid question but figured I'd ask anyway.
Is there any reason I can't/shouldn't use a 1/2 hp low speed grinder motor fitted with pulleys to replace a double shaft 1/2 hp motor for a pair of belt/disk sanders?
Basically I have an pair of old belt sanders, 6x48 and 3x24 that were hooked up to the same double shaft motor for years. Shaft snapped one day and they've been sitting since I'm too cheap to buy a new motor ($200 plus). A new 1/2 hp grinder can be had for less than $100. Am I missing something?
Thanks
DGW
Re: Grinder as motor
Ralph Lipeles
>I see no reason that it should not work as desired.
Pete in Holland, MI
>Did the old motor have a capacitor on it? If so, the starting torque might be a little too much for a standard grinder motor. Also verify the speed of the new verses the old motor.
And.....figure out why the old motor shaft snapped off, else it may happen to the new motor.
No
>No problem, except it would be easier/cheaper to get a regular motor.
Unless you already have the grinder, buying one for $100, and then adding $15-$20 for pulleys is going to cost more than a motor.
I've purchased good motors for less than that. I got a new Leeson 1HP TEFC motor on eBay for about $100, and a 2HP TEFC Baldor for $150. Leeson and Baldor are the top quality motors.
You should be able to find a 1/2HP motor for less than the price of a grinder and pullies.
Happy Woodworking!
GalenV in Iowa
>There MAY BE a difference in the bearings used in the grinder verses the bearing in a NEMA framed motor. The grinder bearings see a uniform radial load based on the mass of the grinding wheel. Some overhung depending on how much force you apply while grinding. The belt drive would put an overhung load due to belt tension. Which has the better bearings is unknown to us. If the bearings were the same size and construction then no problems.
The grinder will most likely have a threaded shaft and may be a little harder to make the pulley stay fixed in place. No keyway and just a setscrew to hold on a threaded shaft.
The grinder shaft may be weaker if the same shaft size as the motor.
The larger belt sander could really put a load on the 1/2 HP motor but if it worked before guess it would again for how you use it.
Just thought.
Galen
JMOHNIKE@PSNW.COM
>Keep in mind the shaft of the motor may not be a true 1/2" etc. so you may have to do some tweaking in order to get the pully on. Also there are no keyways or flats on the shaft to lock the pully in place.
It is no fun running after, or or dodgeing a pully that has come off a running motor. Will the on/off button be in a handy position? A new motor would be the best as stated by another respondent.
Joe
David
>The original set up was the 6x48 sander and a 10" bandsaw powered simultaneously. I took off the bandsaw and put on the small sander. The whole set up was weird. The shaft that snapped was coupled to a longer shaft that used a piece of pipe as a pillow block. That and age are what I'm thinking snapped the shaft.
The difference in bearings and lack of key ways/flats makes sense. I'll have to check into it. Don't already have the grinder but one can be had for about $60. I have pulleys.
Thanks guys...
>I have one of the WoodCraft low speed grinders. I find the motor to be not very powerful. I use mine for sharpening my turning tools and use extremely light pressure and it works fine, but on the rare occasions I have put pressure on the wheels, it is easy to slow it down. I would think a sanding belt would stop it easily.
David
>I think I should stop being cheap and go buy a motor...
Thanks for all the input.
DGW
