Help on tree ID
Help on tree ID
Help on tree ID
>I have 15 acres of hardwoods with one example of this tree. The trunk is about 6" in diameter, and it's about 45' tall. The bark looks like sycamore, but the leaves are totally different. The leaves get to about 4.5" long. Any guesses?
Clint
Re: Help on tree ID
The leaves
Re: Help on tree ID
Re: Help on tree ID
Michael Bush
>Looks like American Hornbeam to me.
Re: Help on tree ID
No, nevermind. the bark doesn't look right
Michael Bush
Re: Help on tree ID
Beech
>Looks like a Beech tree to me. Tom
Re: Help on tree ID
Re: Beech
Larry in NW Ohio
>I go along with Tom, my neighbor has one and looks just like it. Larry
Re: Help on tree ID
Re: Beech
>I'll keep an open mind, but there are plenty of beech trees in the woods, and this guy bears no resemblance to their bark. The pattern of leaves is also different, each twig having a cluster of three.
Clint
Re: Help on tree ID
not like any beech I ever saw
Bill Tindall, E.TN
>It certainly is not American beech. Where in the world is this tree growing? Could it be no-nnative. The bark sure look like sycamore and there are sycamores beyond the american sycamore. I can't find my tree book to look them up.
Re: Help on tree ID
Sycamore
Gene Gauss
>The flaking bark is very close to what we call sycamore around here. In the fall it drops seed balls about the size of golf balls.
Re: Help on tree ID
Re: Help on tree ID
Victor Parisian
>Looks like Sycamore bark and Trillium leaves.
Where are the trees and you located?
Good luck
Victor
Re: Help on tree ID
Bark and leaves are different trees
Tom Dunlap
>The bark is sycamore...leaves look like beech...you should have a much closer pic of the leaves for a better ID.
Re: Help on tree ID
Dale Lenz
Re: Help on tree ID
Dale Lenz
>Leaf margins, edges, are not beech. It is somewhat common, especially in the woods, for folks to be looking at another tree's leaves due to crown overlapping. Could that possible be the case here?
Re: Help on tree ID
Re: Help on tree ID
James Runchey
>It looks like a mountain stewartia according to the picture in the North American Audubon Field Guide. Grows in Kentucky, Virginia, Northern Georgia.
Re: Help on tree ID
Still a mystery
>I'm convinced that it's neither beech nor sycamore, and have not found a likely suspect in any reference. It may be a non-native specie, as the previous owner was a botanist, and may have planted it. It's very attractive and seem to like a moist environment, since the water table is only about two feet down.
Clint
Re: Help on tree ID
Chinese Elm ?
Don Orr
Re: Help on tree ID
East central PA, near Quakertown
Re: Help on tree ID
I don't think so
>The leaf configuration is different and the bark doesn't look scabby enough.
Clint
Re: Help on tree ID
Re: East central PA, near Quakertown
Victor P
>Sorry Clint, I was turning off the computer after that post and just before i did i Googled Haycock Mountain and there you were in Eastern PA.
Its a dogwood tree. I can tell by the...
Victor
Re: Help on tree ID
Re: Help on tree ID
Dale Stansbery
>The bark looks a lot more like London Plane tree (non native, related to Sycamore) than it does to Sycamore. You'll have to climb the tree and hold a branch with those leaves on it showing them coming out of that trunk,and take a picture of them before I believe they're related to that tree though.
Re: Help on tree ID
Re: Chinese Elm ?
Fred Davis
>No
FredD
Re: Help on tree ID
Re: Help on tree ID
>It's not London plane. The leaves and leaf pattern are totally different.
Clint
P.S. I'm beginning to think it was brought here by aliens.
Re: Help on tree ID
That's it! Venusian Sycamore!
Re: Help on tree ID
Dale Lenz
Re: Question
Dale Lenz
>Can not tell from your leaf pic., are the leaves/twig arraigned in an opposite pattern, as in pairs, like the ears on your head, opposite to one another. Have you noticed flowering in the spring, if so what color etc.
Re: Help on tree ID
Re: Question
>As shown in the picture, all the leaves are arranged on each twig tip in a triangular pattern. No variation. They are fat canoe shaped up to 4 1/2" with edges in a fine tooth serration. They are soft, rather than crisp like dogwood or beect, without prominent veining.
There were several, what appeared to be dead blossoms, up too high to really make out, and nothing scattered on the ground.
The mottling on the bark, in shades of gray-green, tan, brown, and coffee extends on to the branches.
On this tree, from the base to about three feet up on one side, where it looks like it had been used as a deer rub and is scarred, the bark is actually exfoliating in quarter size chips that can be flicked off.
A couple main lateral roots show above ground.
Clint
