Repairing Wood Boring Bee damage? (OT?)
>Been working on my cousin's house. The rake boards on one end have been damaged by wood boring bees. Their tunnels have come through the surface, leaving long grooves exposed. She suggested filling the grooves and painting the pieces. I have my doubts. The question is, would you fill them or replace the pieces? If you filled them, what would you use for filler?
And, any suggestions on preventing further damage?
Re: Repairing Wood Boring Bee damage? (OT?)
Bondo
commiseration
Bill Tindall, E.TN
>I fight these critters yearly. One year I killed over 300 as they visited the flowers while taking a break from boring holes in the house.
What I have learned, little of it useful:
They bore in to a board(even cedar!) and then they go laterally up to 12". They lay eggs, seal off the entrance and leave. Then along comes a woodpecker who knows they are there and he commences to chop the grubs out leaving a long gash in the board.
More than one seem to use a hole once the hole is started. I sprayed several entering the same hole on the porch.
A plug of caulk in the hole will leave them to abandon it. Spraying the hole with insecticide does not dissuade others from furthering the boring nor lead based pigment stain which they bore through unimpeded.
Jay Lombardo
>If anyone has any suggestions I too would like to hear them. I fight these buggers every year. They make holes that look like they were drilled with a 3/8" bit, perfectly round. I have tried insecticides in the holes, spraying them in flight, caulk, etc. Every year, same problem.
Jay
Bob Herrman
>The insecticide "DEMON" will kill them. Leaves a residue which keeps them from coming back. They will infest twice a year, so spray both times. With the disappearance of Honey Bees, these insects have been doing their job. However they can eat up your barn or house.
Repair by caulking or bondo, however seems with your damage you need to replace the board.
Larry in NW Ohio
>Just an idea. If you can put a landing or if you want to call it a runway in front of the hole and put some powder Terro or some other powder bee killer on it, you may want to go to a good garden center and get some advise from them on what to use. The runway is for them to land on the powder so it gets on their legs and bring it back into the nest so it kills the queen bee. This should get rid of them. Then you can plug it. Best of luck. Larry
Whack-a-bee (slight woodworking content)
Bill Tindall, E.TN
>Out here in the country we don't have cable so we have to invent our entertainment (when not woodworking), well actually it involves woodworking. First you need to make a thin strip of hardwood about 3/16" x 1-1 1/4" x 32". It should be slightly flexible. So ends the woodworking part. Then find a place they are feeding or boring and whack them out of the air. I was average at hitting a ball and this level of eye-hand coordination is sufficient to achieve greater than 50% whack rate. One spring I got over 300 on a wisteria vine and last year I would try to do 25 a day (50 on a good day) in the salvia garden(for humming birds). It is most satisfying to get good contact and launch one 10 or more feet.
We have winter entertainment. Wife feed birds, including buzzards, but I will save those details for another day.
How about a bee-bee gun ;-) LOL!
mdclor
Re: Whack-a-bee (slight woodworking content)
>That's funny! At my own house they have invaded the trim on the rear. I must have fifty or maybe a hundred holes. We play bee tennis. We had an old tennis racket and would go out and swat the ones attacking the house. At first they sort of buzz you and threaten. Those you can knock into next week. Very quickly they learn you are not threatened and in fact they are under attack. It gets tougher to whack them.
Actually two problems
Lee Schierer - McKean, PA
>Your really have two problems. One is carpenter bees that bore into the wood, lay eggs which turn into larva and pupae (also known as wood pecker food). The other is the woodpeckers that are drilling through the sides of the boards to eat the bee larvare. The only known cure is to replace or cover the attractive wood with a non-wood material. I don't believe the bees will bore into the pvc fascia boards or vinyl fascia trim that are now available. If you discourage the bees then the woodpeckers will not be looking for food.
Lee
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>I have exactly the same problems. I called an exterminator who said that they breed in trees and that it's practically impossible to get rid of them. One question I have: do they sting?
sting? yes and no
Tim Greif - West of Chicago
>Female carpenter bees are very docile and do have a stinger. If you really tick one off, it might sting you, but I think you really need to get it pissed.
Males have no stinger, but are very agressive. They just try to intimidate you by buzzing your head and being generally annoying.
We have plenty around. I've never been stung.
Re: sting? yes and no
>I have no knowledge of the male Vs female thing. I do know that the ones with white faces can not sting. Caught dozens or maybe hundreds of them when I was a kid. The black faced ones can sting, but in all my messing with them I never got stung.
