Replacing Tailgate Cables on Ford Ranger
Jennifer@Indy.USA
>I'm trying to replace the tailgate cables on my 2004 Ford Ranger and am wondering if anybody else has done this. The side bolts on the tailgate just keep spinning and never come out in order to remove the bottom part of the cable. Do I need to remove that cover on the inside of the tailgate to gain access to the inside to get these bolts out? The top end of the cable pops off with a spring loaded doo-dad so that's not a problem. Thanks for any help you might have.
Jennifer
Re: Replacing Tailgate Cables on Ford Ranger
Re: Replacing Tailgate Cables on Ford Ranger *LINK*
Bob Entwisle in NJ
>Not much help here, other than to say that sometimes you just have to start removing fasteners and taking things apart until you can get to the area you need to be.
You can get the Ford service manual info online for about $11 for a 72 hhour subscritption fee at this link. Just select your model and year etc.
http://www.motorcraftservice.com/vdirs/retail/default.asp?pageid=cat_1&gutsid=productdetail
Library?
>You may also be able to find info in the service manuals at your local library.
Tail light . . .
steve mackay
>I have to remove the tail light on my Frontier to get at it. And that darn assembly has NEVER gone back in right !
Sorry . . .
steve mackay
>wrong end. My cable "slips off" at the tailgate end.
Re: Library?
Joanne in Point Pleasant, PA
>I thought this was a good suggestion from Bill last week, when I asked about the turn signals on my '98 Ranger. Then I found a used copy of the Chilton guide online (Borders Marketplace, I think) for about $6, so I ordered it. Not sure it will help me that much, but there are some exploded views of connections like that. But they are tiny and I took the book to work to enlarge the image I needed on a copy machine.
I don't know how different the 2004 is the the 1999 (last year my book covers), but I'll be glad to copy the page with the diagram on the tailgate, enlarge it, and email it to you. However, I'm not back in the office until Tuesday to do it. It doesn't really explain well what to do, it mostly shows the connections. Where there is text on the opposite page explaining how to do things--leaves much to be desired. Let me know if you haven't figured it out by then.
>Sounds like a lot of trouble. This seems like a perfect application for duct tape. You're welcome. ;-)
T.
Red or Green?
Jim Shaver - Oakville, Ont, Canada
Got it thanks!
Jennifer@Indy.USA
>Well, I got them changed out. I did need to remove the access panel on the tailgate. I needed to tap on the ends of the bolts inside to get them out. It was simple enough. While I had the thing opened up I took the opportunity to WD-40 the linkage and stuff on the tailgate latch.
Joanne thanks for the offer of scanning, and Tommy I can think of a good use for your duct tape! :)
My truck is getting to the age that I should probably invest in a Chilton�s how to book.
Re: Got it thanks! *LINK*
Mark Nowicki
>Jennifer:
You might consider subscribing to an on-line manual.
Mark
Alldata manuals
Thanks Mark
Jennifer@Indy.USA
>...I will look into that.
Jen
Thanks, I may do that.------WebKitFormBoundaryks+4
Jennifer@INdy.USA------WebKitFormBoundarycEcbeRyDg
>------WebKitFormBoundaryks+4wzfEscTtzJKb
Red or Green? ------WebKitFormBoundarykmY5B76qnriD
Jim Shaver - Oakville, Ont, Canada------WebKitForm
>------WebKitFormBoundarykmY5B76qnriD+T31
