Computer help (OT)
Computer help (OT)
Computer help (OT)
Larry in NW Ohio
>Quite awhile back I asked help to get my computer back from the the dark side of somewhere. Well I need help again, Of course I forgot how to do that and need to do it again. Do you think that would get rid of the "Rapid antivirus spam" or whatever it is. Thank you Larry
Re: Computer help (OT)
Dan Donaldson
>What are the symptoms?
Same problem? Do a search for your thread.
Dave Bair, Eaton Rapids, MI
Jim Dillon
>Larry,
I've had to do what Dave is suggesting quite often. In the back of my mind I might remember the thread and that I responded, but I can't really remember what the original poster's question was. So I go to the archives and ask for all posts (within a time frame if I remember that) by me. I then scroll through them and usually find the original thread I was looking for. Give it a try.
Jim
Larry in NW Ohio
>Dan I got something called "Rapid antivirus" on my computer. A window keeps popping up every so often wanting you to sign up and saying thatyour computer is in eminent danger of a virus. What`s the best way to get rid of it? Thanks Larry
Dan Donaldson
>I did a bit of searching about it and it looks like it is not an easy one to get rid of. (no simple "run this and it is gone" type thing, at least that I could find) From what I found with what is admittedly a cursory look, success will depend at least somewhat on how comfortable you are hacking into the depths of the computer. A lot of the things I saw to remove it involved doing stuff that can totally wipe out your os if you make a mistake. I can't remember exactly where it is, but there is a site that will take the output of a small program called hijack this and tell you what you have and what to do to get rid of it. You might want to do a search for that and I will try to find out a bit more.
Curly Smith
>These programs are supposed to be able to kill the Rapid Antivirus malware:
Malwarebytes Anti-Malware
SUPERAntiSpyware
If you need it, you can also download HijackThis but be sure to read their tutorial before running it and trying to post the log.
No Help Here
David Yoho
>Larry, if it were me, I'd be comfortable enough with editing the Windows Registry to pull that sucker out by the roots myself. After all, most everything installed in Windows has roots in the Registry. However, that's me and not you. I'd say short of having an experienced person remove it for you, one good alternative already mentioned would be HijackThis.
David
Dave Paine
>Many virus's are difficult to remove due to the way they attach themselves to the operating system.
I normally remove the hard drive, attach to another virus free PC and then have the other PC run the virus scan. This normally removes the virus. If you are lucky the PC will be back to normal operation.
If you are not so lucky you may need to do a manual restore to an earlier restore point. Microsoft has knowledge base article. Do google search for e.g., "manual restore windows xp" and you will see lots of results.
Tell me if I got it right
Larry in NW Ohio
>I think I did something, at least it doesn`t pop up anymore. I went to All Programs-then to System tools- then to System restore. It then brought up a window with a selection of how far back I want the computer to go to, so I just went back just three days just before it got onto my computer and hit restore and it did it`s magic and it was gone. So can someone tell me is it really gone or is it waiting in some dark resess of my drive just waiting to jump out again, just where is it and can it still do damage? Thanks for all your advise, and when my son gets around I`ll have him get these programs and run them Thanks again,I just love this site and all the great people willing to help each other. Larry
Re: Tell me if I got it right
Curly Smith
>By restoring to an earlier configuration you essentially did what Dan and David were suggesting in removing the Rapid Anti-Virus entries from the registry. Consequently, the malware will no longer initiate at startup. However, it's still on your PC waiting for you, or some process, to run the initiation file. It should be much easier for the free anti-malware/spyware programs listed above to remove now that it's not active. Download and run one or more of them and your problem should be solved.
