Re: OT-Fixing Dent in Truck Fender
DonSTL
>Sorry for the delayed response, I just didn�t have time yesterday.
My experience with auto body is (was, as I haven�t done any for a long time) as a serious hobbyist. I have replaced fenders, quarter panels (rear fenders to the layman), rear clips, door panels, rocker panels, etc. I have spot painted, panel painted, and done over-all paint jobs on cars, trucks, and vans, including a few van murals (wasn�t that an interesting era).
You don�t state the age or condition of your truck, but that should have some bearing on your decision to do your own work, because the quality of your repair job will affect the resale/trade-in value of the vehicle.
One of the best suggestions made was to gather information, such as from the library.
Everyone has different standards and I don�t want to offend anyone, but I find auto body repair/refinishing to be much more critical than woodworking/wood finishing.
Finished wood inherently has imperfections that are expected. And, unless a wood item has a French polished finish, imperfections are not nearly as noticeable as on a vehicle with a high gloss finish.
Regarding the actual metal repair, depending on how deep the dent is and if the metal is creased or not will have an effect on how much the metal may be stretched. With the advent of thinner and thinner metal to lower vehicle weight, it has become harder and harder (almost impossible) to �shrink� the metal back to size by working it with a dolly and hammer.
To use body filler, the panel must be ground down to the bare metal with about a 36 grit disk. Filler will ONLY adhere to bare, clean metal. This generally means grinding outside of the damaged area.
The body filler must be mixed with hardener and applied in a matter of minutes. There is no time to smooth and shape until the end result looks just right. This is where experience comes in.
The filler must be sanded with coarse paper to a �roughed-in� shape and then finished using progressively finer grades of paper. Sanding blocks as long as approx. 15-inches are used to blend into surrounding areas.
Finally, spot fillers are used for any minor imperfections and then primer surfacer is used to help �feather-edge� a transition between the body filler and the existing finish.
When you can paint, experience will dictate whether to spray and blend into the surrounding area, back-tape along a panel ridge and spray just a panel section, or spray a complete panel.
The new finishes are catalyzed paint, i.e., a hardener must be mixed with the paint. Your paint may be available as a �one-step� mix, which means the color and clear coat are combined, or you may have to use a two-step mix, i.e., the color must be sprayed, then the clear coat must be sprayed.
I recently purchased a pint of one-step paint, one-half pint of hardener and a quart of reducer (thinner) and paid over $60.
By the way. If your truck is a metallic color, be aware that how well your sprayed color matches the rest of your truck will be determined by the reducer you use, the air pressure you use, the humidity and temperature at the time you spray, and your spraying technique, i.e., how wet you lay down the coats of paint, the distance you hold the gun from the panel, etc.
