200+ woodworking book reviews
Who's got a wide belt sander?
paul woolson
>I'm looking for a wide belt sander. I've been through all of the drum sanders that I care to try. My main problem is that pretty much every piece of wood I pass through is very resinous so it ruins then belts on drum sanders (often in one pass).
I had a Steel City but it died and the tech guys couldn't figure it out, so I had to return it.
I'm hoping someone has experience with one of the open ended 15-16" models.
Thanks, Paul
Re: Who's got a wide belt sander?
Robert R. Clough - Thorncraft
>Paul, I have a 16/32 Performax (prior to Jet purchase) which I have used often on both hard and soft wood plus Pine and other resinous wood which I consider a separate category when sanding. Well, enough of that. Yes there are times when a single pass clogs a belt up beyond repair but usually I can get several passes (120g) on a wide piece before getting a new belt. It is a real nuisance but must be done.
For most sanding I have no problem.
Larry in NW Ohio
>Paul I have a 25" Woodmaster that I`ve had over 10 years and I`m very pleased with and would recomend. Of course I do not have any experience with anything else. It`s a very simple machine, so if and when it needs fixing almost anyone could do it. If you live any place close to Kansas City, that`s where they are made, not China, they will give you a great deal, or you might be able to get ahold of a rebuilt one. Good luck on whatever you decide on. Larry
Ray Binnicker
>Paul,
I, too, have the Performax (now Jet) 16-32 and am very pleased with it. Gum-up can be a nuisance, but un-avoidable. Taking lighter passes can prolong the life of a belt. Ruining a fairly new belt can be dis-heartning, I agree, especially if you are using the pre-cut belts. I started buying my belt in the 50 yd roll and cutting my own. It is a tremendous savings, and it only takes a few minutes to do. Industrialabrasives.com is a good place to look for bulk belt material (no affiliation, just a satisified customer).
Ray Binnicker
Rick L
Re: Stroke sander...
Rick L
>would be my first choice over a drum sander. Takes maore room but more versatile. Belts change fast and are cheap. Also stoke sanders are very cheap, used can often be had for scrap metal prices.
If going with a widebelt, I would make sure the widebelt had a platen or it's just an oversized drum sander.
Larry in NW Ohio
>When my belt gets gunk in it, like pitch, I clean it in a Simple Green bath. I save things like a big coffee can big enough to put the belt in standing up rolled up and put the top on. Soak it in there for a day or so, pull it out and put a screen on the can and put the roll on top to let it drain for a few hours and clean it off with a wire brush and an air hose. Then it`s good to go again. Try it, it sure saves the money. Larry
Rick L
Re: Belt cleaning is...
Rick L
>an industry standard practice we've been doing for 35 years in the shops I've worked in
>I have a Performax 16/32 and made a piece of furniture from heart pine. The belts would clog in a single pass. I cleaned them in Simple Green as described above. A gallon jug with a mix of 1 part SG and 4 parts water. Left them in there over night and then brushed them off with a nylon brush under running water and hang them up to dry. It might work to leave them an hour or two but I don't recall. Try buying them from Industrial Abrasives (cheaper in bulk rolls by about half)or Klingspor (not as cheap, but cheaper than pre cut strips).
